Im guessing if you had an empty bottle in your boot not connected to anything that would be fine. The second you have NOS in the bottle or any buttons/switches fake or not, youre most likely going to be in trouble.
I doubt they could even do you if the bottle was full as long as there is no system in place for the car to use it. Otherwise you would need a permit to transport it?
https://www.sau.com.au/forums/topic/210656-nos/page/2/#findComment-3726041
I remember reading something about this in AutoSalon or Street Machine...
It was something along the lines of it is fine to have it installed... ...and a full bottle in the car... ...As long as it takes a good bit of work to get the bottle hooked up... ...and just as long as you're not driving on the road with it hooked up you'll be fine...
I also asked my local police contact and he said you'd be, and I quote, "A f$%&ing try hard wanna be that would get a defect from the first rookie ass kisser trying to get in with their SS(Senior Sergeant)"...
I'd say put it in a trailer queen or a track car... ...and just keep it off the street...
https://www.sau.com.au/forums/topic/210656-nos/page/2/#findComment-3726981
Any of you two got proof for what you typed there? Last official documentation I read agrees with Al in that you cannot have ANY part of a NOS system connected to a road rego'd car.
I do not have documented proof, but asking for curiosity sake a TMU police officer and a NOS supplier in victoria and them both saying the same thing is enough for me.
https://www.sau.com.au/forums/topic/210656-nos/page/2/#findComment-3728081
I would definitely get a second-opinion from the police officer, it sounds incorrect.
And if I were a NOS supplier, of course I'd tell you it was legal, I'd want to sell NOS :)
https://www.sau.com.au/forums/topic/210656-nos/page/2/#findComment-3729779
lol stop provoking the young fella, or being stupid and saying you can have this or that when you officially know nothin and you actually know you cant have the bottle. just dont believe those guys they want to see you make a thread one day saying you got a fine for haveing this this and this in ur car and all they want to do is laugh at you just dont do it or get one you just wasteing ur time and money on stupid things which give all of use skyline drivers a bad name to the cops, anyone agree?
https://www.sau.com.au/forums/topic/210656-nos/page/2/#findComment-3730601
when the police impounded my car they had a look over my car. he said he was just having a look and isnt doing a roadworthy inspection, when he was doing so he said if he seen any part of a nos setup my car, he would put it off the road.
Edited by R33GTST4Door
https://www.sau.com.au/forums/topic/210656-nos/page/2/#findComment-3730679
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
