Here are some pic of the stock GTR BOV setup. they are from a friends 34 but i own a 33 and its the same. dont have the ones where it plumbes back in the IC picping but i think this can help you on your way.
Sorry Michael, slipped my mind :P
I thankfully had these pics already on me.
I don't have any with IC on, but you can see where it bolts to the BOV return.
Let me know if you'd like something from another angle etc and I'll gladly get the camera out.
Edited by GeeTR
ohh one final question is the reason why most j-spec oil cooler kits run on the turboside duct because they wont fit next to the bov setup?
My pleasure :cheers:
I would say yes, BOV's large form factor is one the main reasons. I would say people opening up the passenger side brake duct for the air filters, is the other one. Getting so cold, running the core in between rad and IC must work well for them too.
You "can" fit a oil core in the drivers side... if you fab'd up a new BOV mount, or simple used a smaller, after market BOV.
Edited by GeeTR
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
