Looking into fuel pumps at the moment. Have had quite a few quotes so far...
All the nismo, Tomei etc etc fuel pumps are all around the high $400 mark...
Sard slightly cheaper...
And then Bosch and Walbro around the $200 mark...
Would they be ok for around 300kws in a R33 GTR?
It will be a DIY so i know nismo would be the easiest to put in but for half the price its worth a bit of mucking around...
any ideas?
Or any one used these pumps, pros cons?
Have searched and had mixed results from all those pumps!!!
Or if anyone can get them cheaper or know where i could get them cheaper???
cheers
https://www.sau.com.au/forums/topic/210788-fuel-pumps/
Personally i'd go Nismo or HKS. It's a little more but it's much easier to work with. Bosch are good (i have the 040, no complaints) but in R33's at least, can't reach the bottom of the tank and aren't as reliable on hard cornering, but i just don't dry the tank out so isn't an issue.
Also there's no cradle modifying with these drop in pumps. If you REALLY want to save money go Bosch/Tomei, but on a GTR especially you want something reliable and for an extra $200 you're getting an easier job and less to worry about down the track.
My 2c
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3726452
My 2c
You won't save much money buying the Tomei when It's around the same price as Nismo and HKS
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3726473
So many threads bout pumps, im getting dizzy :)
Its not that hard.
If you don't want to fiddle, cant use hand tools and want a solution you prolly wont have to think about… ever again, then slap ½ a G on a Nismo bolt in – Done, so simple, you'll forget which pump you have when asked.
If you live to tweak, can use hand tools, and don't mind playing around with things, then go the non bolt in option, and stick in your [iNSERT PUMP MODEL HERE] in tank.
The pump has NOTHING to do with G forces, fuel gauge etc blah blah. Clearly one needs to mount the pick up sock in the same location as factory… to get the same factory result. This means not using 2nd hand hay twine to tie the pump half way up the cradle support. It means thinking about line flex, material, line runs etc, as to not impact other systems.
/end rant haha :(
Edited by GeeTR
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3726514
+1 nismo [and I am handy with tools]
U then, clearly possese a spagina, and like man tools :)
Jokes :nyaanyaa:
No worries = plug in. Save some $ = doit urself - if i was rich and had no care for mechanical symbiosis... id go Nismo too (and debate it black N blue)
Edited by GeeTR
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3727543
Me, if I fitted a bosch, I'd weld up a frame that the bosch would sit in just like a std pump, then I'd get the frame bright zinc coated so it wouldn't rust etc then I'd be half happy---------but this would cost as much as a nismo in the end and be a bit more mucking about------------and don't tell me I'm overdoing it, I've fought my pedanticism all my life and lost every time.
If I didn't do it like that I'd be going down the road saying 'Yeah, I got a bosch, but I'm going to take it out and fix it up soon!!!' and would always be nagging/noring away at me until I did.
https://www.sau.com.au/forums/topic/210788-fuel-pumps/#findComment-3727786
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
