I recently went for a top speed test in my car, even though it has a 180km/h speedo ;) (In closed course test conditions only). However it has this annoying, and slightly suvere engine cut at 7500rpm in 3rd, 6000rpm in 4th, 6000rpm in 5th, which is around 220-230km/h. Is this normal, the speed cut or something? If so, i thought it would be quite gentle, and at 180km/h. Its like you turn the ignition off for around 6 or 7 secs, then fires back up. Happens the same revs in those gears each time, so it wasnt a random thing.
https://www.sau.com.au/forums/topic/21082-3rd-4th-5th-gear-engine-cut/
it's called Rev limiter...... 7200 rpm max.....that is a violent shudder
Speed Limiter:
the car should go duuh dsuuh duuh duuuh duuuh duuuhh when 180kph
more of a strong vibration shudder......
Well that's what i feel.... on the track
:P
Could be maxing out the AFM and it flows more when you load it down in higher gears... how much boost are you running?
If your hitting 230 ish that's way past the factory speed cut on the ECU and i would say that either, A: whoever installed the RB20 in your 180SX didn't hook up wire 53 (Speed sensor to ECU), or B: Your ECU's been chipped and the limiter removed (if this is the case it shouldn't air flow cut)
Doc.
Hmm.. when you say 230 at the wheels, KW or HP? It wont be puttting out 230kw, at the moment i have these mods:
RB25 turbo @ 14psi
3" turbo back exhaust, with seperate dump
PWR FMIC
Pod Filter mounted behind front bumper
Stock un-chipped ecu
Stock afm, just taken rear mesh off but did it before that came off
It has also happened in 2nd gear, when i was doing a burnout up a hill, it was revving between 7500-8000rpm and was pinned for a 10 secs or so, its pretty dangerous because the engine just shuts down for around 5-10secs then takes off again. Also my BOV leaks around 1bar, not sure if this would cause a problem but im going to get another one.
I was actually refering to your speed.... If you can go past 190 km/h (some 180 speed cuts are a little off) then either your speed sensor wire #53 is not hooked up, or it's chipped.
If i ran a diagnostics wouldnt it say if wire 53 was not hooked up? If it isnt hooked up what will it do? Also if the AFM is maxing out, why? I was told it would be good to a bit over 200rwkw, and cant see that my car would be making that much power. Ive been curious if it had been chipped before, because i have problems with detonation at 5700-6500rpm, but if i run octane boost it is fine. Just guessing that it was mapped for japanese fuel, not ours.
Do you mean take the kick panel off and take a photo, or take the ecu apart and take a photo of its insides? As for the cut, i guess so. But it will cut out in 3-5th gears any time.. Ive only reached 6000rpm in 4th and 5th at night, and ive only had the car for a few months so its always been cold. But it has cut out in 2nd early morning last week.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
