Hey if Lofty can do 1.17's in his NA 2 litre Toyota Starlet in IPRA form on crap controlled Yokies, why couldn't a car with alot more freedoms and HP/PS/KW go alot faster :D
The most important factor, TALENT. Unfortunately money can't buy it. :)
  • Replies 1.9k
Here is some in car footage from my mates street registered 400hp s14 at Oran park GP
This car does 1.07's at wakefield (old surface). Flat 48's around Oran South and a touch under 1.20 around GP.
This car is running semi's (RE55s).
This car is a consistent front runner and class winner in the Multi Club Supersprint Series in NSW.
I would be very surprised if a street registered car on street tyres could do 1.18 around GP.
Edited by blacksx
Was it you who bought my Brembo's and rotors?
Superlap will be full of surprises!!!!!
What times does this car do around Eeastern Creek???
That's very impressive, street registered rwd 2 litre punching out those times, must be a great steerer too!!!!
Troy (aka Roy) has some stiff competition!!!!
But Troy's racing "twoogle" :laugh:
got a spare pair of -5's hanging around?
JAGR33,
The car in the video is consistently quick. But there is a lot of road registered car's doing similar times.
This car will not be entering superlap. As it is pointless trying to push a 200sx on street tyres around a race track.
Unless it's a drift event which it clearly isn't. These car's need semi's to go quick.
JAGR33,
He should still enter it, will be a great event who cares if there are faster cars out there???
Anyway, still impressive in what your mate has done.. :laugh:
JAGR33,
That S14 looks very well behaved for 400hp! Steerer looks smooth and is on the ball doing those times.
JAG, if you guys did EC as often as you have Sandown/PI etc i suspect you would all be doing around 1:42 to 1:44s. I think that EC is a pretty technical track compared to some down here in Vic. I really need to run my car again on some NSW tracks, never ran on any of them with semis and the TD06 :laugh:
You would really needs 18s on a rwd car in teh Clubsprint class. The extra diam and lower profile would have to help a car on street tyres.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
