  • Replies 1.9k
I must have missed that on the site.....thanks for confirming.
Still not sure how that can be enforced if it is under a CAMS supersprint permit.
Nathan form superlap might like to add to this as it seems like a few more people may like to run in open but can't because of this rule.
Yeh, but my crashes always look spectacular :)
Yeh i read the regs, seems a shame :D Personally i would love to have a go against the RB25 R32 GTSts with the little 20. Everything to gain, nothing to lose :)
pride
bragging rights
putting your propaganda back a few years.....
There's always something to lose ;)
pride
bragging rights
Pride, pride? LOL that is only for the proud :) And rule number 101, you dont have to be right or even to have won anything to still have bragging rights, especially when the basis of all my bragging is baseless.
On the last count, you are right. :) I do hold all my propoaganda dear to heart. I will have to work on my list of excuses and my baseless bragging to turn a loss into a victory :D
Yeh, but my crashes always look spectacular :D
Yeh i read the regs, seems a shame ;) Personally i would love to have a go against the RB25 R32 GTSts with the little 20. Everything to gain, nothing to lose :glare:
I totally agree with you, there should be exceptions to the rule, my R32 Gtst has an R33 Gtst RB25DET and its not the most powerful or fastest car around and because it doesnt have a cage it means that I cant compete in either class so Im pretty much screwed completely...
Its a shame because Im sure that Im not the only one in this position.
Just get a cage...
- They aren't very expensive. Cost should be less than a decent set of semis.
- It may well save your life if something goes wrong.
- It helped the handling of my GTST a lot.
Helped the handling of your car? I understand the theory but personally there is no way on earth i can look someone in the eye and tell them i can tell the difference from either lap times or seat of the pants. The only time i notice it is when the car is jacked or im going out steep curbs/driveways at an angle.
That said a cage is a sound investment in your safety and also means you can properly run harnesses. Most harness installs are a good chance of injuuring a driver in an accident :(
Just get a cage...
Not everyone wants a cage in their road car mate :(
I found with the GTS-T that it made a big difference to how stable and predictable it was through the corners, I didn't notice an improvement in laptimes, but I wasn't slowed down by the extra weight of it either! That being said though, the GTST wasn't the most structually sound car around, it had more than one monster accident in it's life time and was very bent chassis wise.
In comparison, I haven't noticed a difference since I put it in the GTR.
Merli, theres ways around that, a bolt in cage would be a good solution, put it in for the track days, pull it out for driving around the streets. Or even just have bolt in front bars and a permanent rear cage.
All Open Class entries must have a minimum half cage, but we recommend a 6 point roll cage.
This is also a bit harsh on guys in S13's with stock standard SR's replacing CA's.
Cheers
Gary
I have found that a rear half cage doesn't make anywhere near as much difference as a full (6 point) cage. Then the number of attachment points also comes into effect, particulary if you go though the firewall to front strut towers. I addition, after full cage firtment, the suspension almost always needs retuning to get the best out of the car. If you leave it alone, it may well have too high spring and hence shock rates, plus a reduction in camber may also be of benefit. I have seen cars go slower (lap time wise) after a full cage was fitted, until we retuned the suspension. Interestingly enough the brake bias also changed, with the front able to handle more braking effort than was the case pre cage.
Cheers
Gary
blacksx - he wouldnt even be interested running on the falken's or the 595 rs'?
Yeah its a very quick car, regardless - if it were me I'd still enter and have fun!
Blacksx should also be attending superlap... he is no more than 0.5 second behind boxhead and a good steerer himself.
Cheers
Gary
My head hurts. Which is why i have stopped caring about future mods and have just gone back to enjoying the car on the street. When i can afford to get out there i will, but have given up chasing times.
For the first few rounds of these events are Superlap not best to loosen the rules and allow as many competitors as possible?
Great point, it ensures as many people as possible will be there maximising not only numbers, but their own personal revenue :(
......but i doubt they will do it
+1
Personally im against having a cage in the car, and pulling it in and out is very much easier said than done - anyway, when i was buying the car i didnt even bother looking at GTR's that had been fitted with cages even if it still wasnt in there
Cheers
Gary
Exactly the case with my car. It did take a while to get sorted but it is so much better having the cage in. The chasie responds to setup changes and is much easies to tune. I have also found that I have needed to take some rear brake out of it too.
But they came std with that engine so shouldnt be an issue. I would expect an engine change is fine as ling as it came std in that model
But the CA equipped S13 chassis are lighter than the SR equipped ones. So the converted cars have a weight advantage over the non converted ones.
How about the line that R32's came with RB5DE's, adding a turbo shouldn't put you into the Open Class.
Cheers
Gary
The point is - If someone in my position wanted to attend this comp just for fun but was told that they cant compete in the Clubsprint class because the car has a later model engine in it (even though its not that powerful) and they cant compete in the Open class because the car doesnt have a roll cage, what are they supposed to do? Buy a roll cage and fit it before the event (which Im sure isnt cheap or easy) or swap the engine back for an RB20??
I dont think that you can make a blanket rule like "no engine conversions can compete in clubsprint class" because its pretty vague...
Perhaps the rule should be judged by power to weight ratio?? :D
Cheers
Gary
What about if one car is blue or if one car is red. Silver looks the best but not as quick as red. :ermm:
Hats off to anyone that runs off and actually builds a car specifically for this event/series. If ppl want to go to extremes and build a class winning car...then they should be able to. If the rules change then change the car that you built to the series rules.
I wouldnt go to that extreme. Fact is its a good way to get a cross section of cars together to see how they perform. If people start trying to build cars to exploiut the rules, then more power to them....but the organisers could find themselves changing rules to fill the gaps....its the risk they take.
Im not saying i am for or against the regulations. It doesnt matter what we discuss here. There are things i would do the same, there are things i would do differently. Fact is if i am not OS i will be there irrespective. Im sure most of us can squeeze our cars into one class or another.
(So yes perhaps relax the cage rule in open class.)
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
