Be carfull with getting wide tyres on a front engine rwd. As I found good 285's - 335's are all designed for rear or mid engined cars that have a lot of weight over the rear wheels. In a front engine rwd you will never get the tyre working properly to generate any grip. Dunlop do make a good 285 but again its in a hard compound designed for Porchers :(
  • Replies 1.9k
Our car was 30K...but then broke the world record for labour charges for a GTR street engine build (no, unfortunately we didn't build this one) So yes you car may be cheaper than ours...hehe
Is that from the same people who brought you "2hrs labour/install for a plug-in ECU" ??
Dunlop do make a good 285 but again its in a hard compound designed for Porchers :D
Woops Dunlop do make a good 295 not 285 but it is for Porchers. There is a 285 in a Bridgestone RE55 but you will never fit it on a jap car as it is way too tall. Again it doesnt come in a soft enough compound for a front engine rwd :laugh:
thinking of running a book on what our best time will be.
bit like a guessing competition, contestants nominate a lap time to the nearest 10th of a second...$10 to enter...winner takes all. Nearest to the time wins or 1/2 the cash if tied.
so who's in?
Woops Dunlop do make a good 295 not 285 but it is for Porchers. There is a 285 in a Bridgestone RE55 but you will never fit it on a jap car as it is way too tall. Again it doesnt come in a soft enough compound for a front engine rwd :O
I'm running 265 wide Re55s on my GTR and a couple of the guys at QR are running 285s on theirs... ?
edit: Paul I havent used one on mine but really need one. Have watched the guys with one at QR in comparison to me and corner exit looks a whole lot more pleasant than without one!!! lol
Edited by wrxkilla
Our suspension mechanic looked at some details on it today...he's impressed with it. Im sure Luke will get the best out of it.
I think we are running 285's on the rear of the Honda S2000. Just got some new wheels so that they will fit in the standard guards....yeah baby.
can i use your old ones boz the hq rubber is to small 195/60/14 but the white walls look great on the gtr
How are the tyres coming along Jas?
I have some spare white walls if needed :D
I think they are only 12 inch in diameter as they may be from my old Datto 1200 days.
Edited by Bozman1
Ruzic ATTESSA controller going in car this weekend...anyone got one/used one?
Currently run one in my 33 GTR. I like it. Allows for more control over the power shift. Certainly makes my front diff work a litter harder (and hotter) as I tend to have the power transfer come on quicker than standard. For want of a better word, gives you more "feel" and more controlled power slides in tight corners.
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
