We came 15th out of 40 in class and 16th overall out of 74. We will be aiming for top 5 next time round. Might need a few more laps and better than OEM brakes to do it though. The cars probably good for a 1.14 set-up how Luke wants it...he was on a 1.16 on his last lap before stopping due to oil in engine bay.
Edited by DiRTgarage
  • Replies 1.9k
What an awesome event :D
A big thank you and congratulations to the event organizers for putting on a spectacle which was well worth the time, money and effort to get the car down to Oran park to compete in.
Great turnout, atmosphere and live commentary. In my opinion it really helped the race teams see where they where in terms of ranking and the blow by blow battle between the R32's and Lotus's was fantastic to hear from a spectator point of view.
Was fun to watch the Hipower Racing CRX keep a few of the GT-R's and Evolution's honest in open class. The team is already planning out what it can do for the next event to improve on it's 1.19, wasn't too shabby considering it was a first time on Oran park for the car.
The point I'd like to stress for the next Superlap would have to be the call for more on-track marshals. I was standing at the closest spectator point to the roll over of the Evolution and it took way to long for the incident to be communicated to the drivers; or race control who were running on the circuit.
Looks like it was a great day, apart from the incidences of course.
I'm really dissapointed I couldn't get there, but what can ya do I guess... congrats to all that ran :D
What happened to the side of Adz's car? Sand trap?
Richard: Sheezus!! He drove around the track like that?
Thanks Beer Baron.
we had lots of fun in the silvia . 17th outright even beat lots of awds. 2nd fastest rwd and awarded best presented car. lots of sideways action.
how can you beat that. and i drove my own car.
I don't think the RX7 spilt any oil did it?
In his defence, it was probably just burning oil, not spilling it, since one of the seals blew.
Although why he went around another lap is beyond me.......................................... :P
Yeah i had a good look at the track after he went past and didnt see a drop. We probably dropped more oil than him. :(
Already got a decent catch can set-up (same as twoogle's) ready to go on the car to prevent the disaster we had on Saturday.
Hey DiRTgarage we were on a 1 min 10 before we broke traction.
Slot car came 6th. Missed the all important top 5 but considering the top 5 open class cars are big budget cars and teams, not so bad I guess with more in it. With softer rear springs required as she was oversteering a lot and bit less neg camber in front as inside tyres in front getting much hotter than outside and understeering a bit. Lots more in the car yet. This one was huge and next one cars will be better and event will be bigger.
Also big well done to Russ giving that R35 heaps and pushing it hard enough to come off the track, so not holding back. Also Mark just being beaten by those pesky Lotuses? Still awesome time though. Not sure how I will ever catch you guys, maybe a bigger rear wing??
Actual Times here.
Superlap TImes.
Edited by Boosted Zed
Thanks to the local exhaust place, my car is now running again and able to be driven. Next stop is the panel shop for the rear bar and supports....
Some great photos getting around...
3 seconds before impact !!!!!
Rear shot of complete tosser... "jeez Brett, the front of your car doesn't look too good" says the old dude
so where was sydney kid and son of. come on, let's get stuck in.
I heard paul say that united forklift rentals needed SKs RB30 back for their forklift... any truth to that?
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
