  • Replies 745
What about the Mongrels... what did Josh say they were worth?
they are a really good tyre for what they are... and now in 33 x 12.5... they sound good... some new suspension and body blocks and emma's lux would be looking tuff...
when do you get your big rig Brocky Cutter?
Hey Actually here is another topic for this CQ Performance Thread... I was talking to Darren of 180GO fame and I asked him a few questions about brake upgrades for Clubsprints... He told me that I needed to Take off the Metal backing plates for the disc brakes... now I know this seems obvious but is this a good move for a street car... does it protect the rotor more than it matters... what about does it act like a heat sink ( draw heat from the disc) or does it trap in heat?? I think it traps heat, and I personally think if you brake a rotor you are probably doing the wrong thing in your import (eg. 4x4 competition or something)
what do you guys think?
Also he actually recommended Bendix Ultimate Pads... he said if I had the money go with Endless NA-R but otherwise Ultimates are the Go... I thought there would have been heaps of pads better than the old ultimate... but he seemed to think they were really good for the price... so maybe that is something to think about next time you are crying just thinking about the price of big name Jap brake pads.... stick with the old Bendix Ultimate!!
I'm still chasing interested parties for the trip to Brissy at the end of this month... it will be simply awsome with a few cars punting around the track... and don't think your car is to slow... I can show you some video of a stock early pintara thrashing around the track in Panda Colours... it is really open to ANYONE... JR that means your mirage to...
Actually it would be awsome to have enough cars there to have our own bracket (7 cars) on the track... all CQ motorsports fans...
Hey brocky cutter...... are you a rtuckie or sumtin.. coz my dad is a truckie. he has a Kenworth T904. Best one around!....
Wanna know why. its a RICE RIG!!!!!!!
$8000 worth of shinnie stainless steel on it.
and. umm.... Couple of blue neons. on inside and out!.like behind the front grill....
Pioneer Head unit- : Front speakers - Fusion
: Rear Speakers - Alpine
: 10" Pioneer Sub, all amped up by a little pioneer amp.
Oh and a t.v and video player
Hoo roo
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
