  • Replies 745
No, still waiting on the headers, these things take time and money, I not know what I am wanting to do first, the car is like a two year plan I hope by the end of two years it will be finish to a point I am happy, have to higher stand then again that has always been me with things I buy.
The exhaust project fully finish is like $1,500.00 around about. so getting done in stages. Apart from that I am buying up speaker compoents at the moment, like I have already spent about $1,500.00 at Rocky Car Sound with only a headunit and alarm plus more gear being held for me.
Originally posted by Sciby
Dude, relax. It's all good. First time out there, no one's expecting a record-breaking pass. :cheers:
And those stats are never really accurate... my gts should be about to break 14s, (I hope) and you're faster than I am.
sciby if you don't do 14s I will eat my hat. Hell i did a 15 flat when my car was stock and running. I managed a very average 14 with more engine issues than you can poke a stick at .... you should creep into the 13s ..... well I think anyway ..... Dev relax you'll do a 13 .... but 12s are more likely ....
Originally posted by Bling_Bling
Who cares it just all fun that whole idea hey.
We will, its just fun to try and guess what times a car will do. althouhg last time i had quite a few people tell me that i would do a 13 without adoubt but I never ended up doing one so it was a bit disappointing ......... hmm I better shutup now don't want to have some be disappointed in their car .... anyway guys a 13 second street car is still damn fast and would beat the majority of cars on the street .....
Originally posted by Nissan = Good
Sames. It would be cool if everyone could just mellow. Anyway How am i going to mount this camera in the car on saturday and not get in the shit?
Very easily, the people at the drags dont seem to mind, we have strapped camera's in loads of peoples cars, from DC's to Big bills falcon. Just make sure it is in tight, both times we have just dodgied it up and used the camera strap as the support.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
