  • Replies 163
Posted Images
I'll be there on the 23rd March for the grand prix circuit!
There is another grand prix circuit practice day on Tuesday the 1st of April!
All you people working on Sunday come to this one.
Edge - I could try and swap my days and head out on the tues....maybe...
I'll keep you updated :)
I'll see how the car goes this sat...might need new pads...among other things :P
Actually - looking at it now theres a good chance my car will need a break! :D
we'll see though!
20th North Circuit
23rd Grand Prix Circuit
25th South Circuit
31st North Circuit
April
1st Grand Prix Circuit
Must have at least a Cams level 2 Speed Licence
Cost is $130
Starts at 9.30am till 4.30pm
"Must have at least a Cams level 2 Speed Licence"... that sounds bad (for me).
Sorry for the question - but how does one get a level 2 licence, particularly by the 31st?
I don't think I'll like the answer... :D
I'd really like to do Oran park before I move interstate in mid-April.
Easy as, its just a form you send off and a small fee :)
PM me if you want help with it
Easy as, its just a form you send off and a small fee :down:
Thanks Steve-O, I might take you up on that :P
I'm just having a quick look at the form and it seems you need to be in a 'Cams affliliated car club'.
That'd my first hurdle, I think :P
Cheers
Guess who's one of those clubs? :P
Really? Heh... I did think of SAU but thought nah... :down:
Anyway I'll go through the form fully tommorrow when I'm more coherant and if I get stuck I'll call for help.
Goodnight :P
Edited by Wayne_J
heading out for the 1st Duncan??
Ill have the GTR brakes done by then so might take both cars for a thrash and spend some time to get the bias and suspension working together again.
I want you to take my thing for a spin and give your oppinion.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
