the bonnet has nothing to do with crumple zones or any accident stuff it is just a lid to stop water getting on your motor so you may change it for carbon or fibreglass... providing it doesn't have any 'protrusions' like vents etc that may stop a pedestrian from rolling over the bonnet in the case of an accident
this is what I have been told by someone who does roadworthies for a living... but I can still imagine you copping grief from the boys in blue... depending on where you live
but saying that....www.carmate.com sell them and im sure most if not all bodykit places would sell them
If you read http://www.carmate.com/termcondition.php about 2/3's of the way down there is a line saying:
All parts forsale at Carmate are recommanded for Show Conditions, not for Legal Street Used purposes.
Just because they sell them on their websites doesnt make them legal for street use.
As far as i know carbon bonnets are 100% illegal for street use. There are no ADR approved ones available as of yet but that may have changed recently.
I'm confused.. doesn't the r34 gtr vspec 2 comes with carbon fibre bonnet? Does that also makes them illegal on the street even though its from factory?
Could possibly be that they are illegal in australia, even though its from factory but when going through compliance to make it Australian standard, a aluminium one is put on and then replaced after registeration.
Anything factory is almost always fine, look at all the exotics going around with their factory loud exhausts.
The reasoning is that its all engineered correctly unlike some cheap carmate one
Edited by Yawn
If you're in QLD, I can personally vouch that carbon bonnets are illegal as I got done twice in 8 days...
However, you can definitely get some aftermarket bonnets engineered... Carbon fibre ones can be engineered but they have to be sent away for crash testing so if you want it engineered you have to get two... Expensive and not worth it considering the fine is only 1pt and 75$.
just dont drive like a hoon and u wont get pulled over as much n they mite leave u alone.
i got screamer n loud exhuast n bells n whistles here and there n if a cop is next to me i smile and drive normally.
its all ya gotta do but i understand they have bad days too.
but yeh carbon is definately illegal coz if u have a head on the bonnet doesnt bend it stays as one and can push bak through the windscreeen and behead with you lol
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
