Can anyone elaborate on the limitations of the e-manage when used on an automatic series 1 r33 gts25t.
I have read that you cannot use the ignition control harness on automatic Nissans. Why is this so? Will this be fixed by Greddy in the future?
I assume it is still possible to control the afm and injectors successfully.
If the ignition control remains unusable on an auto, would an exhaust cam timing wheel offer some benefit?
https://www.sau.com.au/forums/topic/21108-e-manage-automatic/
Taken from the sticky e-manage thread in Forced Induction Performance:
Originally posted by Dr_Drift
Hey guys Just thought I'd share my experience with e-manage. The only significant limitations I've found so far is that you cannot use the ignition control harness on automatics, and the speed limit as previously mentioned.
I've read something about melted coil packs as well. It may have been on the Yahoo e-manage group.
I don't think it affects other ECU's (ie Motec). I think it is just an e-manage issue with auto Nissans. So auto Supras should be OK...
The Dr knows all about this stuff.... Maybe he can elaborate?
I remember Dr Drift saying something that this is one of the limitation of the e-Management with Skyline. That's it doesn't work with the ignition harness or something.
Would be intresting to find out, cause I was thinking of installing the e-Management as well with my auto. No chance with the Power FC and the HKS F-cons with auto. Motec might be too expensive, my mechanics also mention Links Computers but don't know how good they are. Also Unichip but don't know if they will work with auto either.
Damn auto!! hehe :P
Strutto - Thanks for the PM...
Here Goes....
It appears that the automatic's wiring in nissans do in fact read the RPM signal from somwhere (haven't investigated where yet).... This signal going through some extra wiring to the auto control unit causes some minor electrical interference. This interference is picked up when trying to tune the e-manage. I assume this is due to the e-manage being more sensitive than the factory ECU. I am also assuming this is the same reason that neither FC's or FCONV's are available for automatics (maybe link's aren't either)??
My problem so far is that I have only tried tuning e-manage (not fitted by me) on one automatic car which was severly accident damaged by the owner a week after my initial attempt. The car has since been repaired but I think the owner is no longer looking for the extra power.
I have had several suggestions on how to rectify this problem, ranging from resistors inline with certain wires going to the e-manage which have RPM based signals (CAS, IGN, INJ), and to also try and run shielded wiring for the emanage.
All the other ECU's I've seen run shielded wiring right up to the ECU which the e-manage doesn't, so this would be the first place I would look.
Skylineakt - As far as fuel tuning goes the E-Manage is excellent, and a much better option than an SAFC or similar.... Perhaps you would be interested in a discounted supply/install and allow us to research this problem further on your car? Worst case scenario is that you have more power with a perfectly tuned fuel curve... Best case scenario is that we will discover how to maximise the potential of the e-manage for all our skyline brethren the world over???
Doc.
  • 6 months later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
