  • Replies 54
As I said to you when you were sending me "Blow by Blow" updates.... that's baller as f**k mate.
I hope to break 250 with mine, let alone 291 LOL....
We need to hook that boy up some sus and brakes on that thing now :D:)
Edited by R31 drift pig
Very impressed with the numbers however at the last minute we suspect the exhaust cam is a tooth out as with the stock cams the power came on alot earlier....Will keep you posted with more information
cubes, only specs on the cams i know is 264 duration and .64 something. thats all i can remember offhand..cost a bucket!
here are some pics!
Be interesting to see the results. Im betting the std cams will get it on power sooner, and probably make the same power anyway. Rb20s have pretty big cams std
ok dave here is just the sound track no picture 420kb
>>Michael 297kw Soundtrack<<
EDIT
for those that may want it on there Nokie Phone or MP4 compatible device i have it in a 320x240 format weights in @ 12.7mb oh and i took the soundtrack out
Yea steve, id love a copy for the nokia.
We're very pleaseed with it so far, haven't finished yet. Still some fine tuning to go. a fair bit more work smoothing out afr's and also ignition timing...but very pleased with 16psi tho...have plans for a little more boost with a little less timing just to experiment.
And
might i add, its a real animal on the road. >_<
Ryan
GREAT WORK !! Sleeper and a half !
Did you do any head work at all? Definetly still a 20 right?
yep hehe still a 20 dude, head work was really only a clean up. Valve seats and valve stem seals...but nothing performance wise.
mmmmmmmmmmm, i have the exact same turbo on an rb30 twin cam and i only make 254rwkw's @ 14psi!
hehe yea as i said, the 20 only made 250oddrwkw on 20psi before the cams...quite impressed with the way the cams turned out. Alot of money tho but the cams also eliminated a few dips higher in the power curve. We suspect was due to airflow. They disappeared straight away.
more to come in the way of earlier power delivery..
thanks for your comments guys, this was merely just a test car for us to learn how to tune. Big reps to the Microtech and the pc interface.
Ryan
Edited by Ryanrb25
Wasn't 250rwkw odd made with ~12psi once you done the cams and port matched the turbine housing + on a 35+degree day?
Once you push 15-16psi in to yours it should be up around 280rwkw.
Then the usual 18-19psi and 300rwkw which is the norm for an rb25det, rb30det with std exhaust manifold.
Swap out the std exhaust manifold and you could make 350-360rwkw without too many drama's.
But yeah.. it doesn't really sound all that angry in the vid + 16psi for 300rwkw with an xr6t turbo on an rb20 with cams does to my self sound a bee's dick high especially with a std exhaust manifold; but I try not to care. :D
It would be interesting to see how much more is in it on that dyno as the std exhaust manifold on boostworx dyno really struggles once you push 290rwkw. Increasing boost nets small power increases and tops out around 300-310rwkw absolute max. Regardless if it has cams, big turbo's or what not.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
