sadly no. it was badly abused years ago and shut down the whole forum briefly. so I don't think it will be coming back for users any time soon.
Oh that's a shame :P
What if it's members you know and love and trust??? :D
Yeah what Doof said...
It would help me loads, as being on the commitee with organising events I have to send lots of Pm's to keep people informed of what's going on...
Even if it was just the CC feature that would help immensly to "some" of us members
use the search button.. or even scroll half way down the page.
http://www.skylinesaustralia.com/forums/Se...ms-t205366.html
I did actually and nothing came up..so I started a thread..
I only search in this section also
The facility is there.
But for a 'one off' not really.
If you were say, a club secretary, then yes it could be turned on for that specific user ONLY... but thats about the only option
I am Vice President does that surfice?
I'm Doof...
I await my mass PMing abilites...
PS: There's only 3 of us that need it... CARN!
Wrong
whats wrong steve?
someone who can understand forum security (funky? merli?) can we turn this on for club execs in all states?
First post from my blackberry, shouldve been longer - sorry about that
What i meant to say is that execs only should have the ability - not normal users
Leave the NSW committee debate out - no relevance :)
If C is happy to enable this for Exec then as Mark said, wont be hard.
Again though, his forum - his security as it opens up the door a bit with 20-25+ users getting access to a restricted function
    • I did basically the same procedure on a ZF6HP but the reason to pull the valve body is to replace the seals between the valve body and the transmission which are notorious for leaking pressure with age causing poor shifting and burning out the clutches. If you just wanted to exchange all the fluid you should be able to undo one of the transmission cooler return lines to drain into a bucket while using the pressure filler to keep it topped off.
    • The title should have posted "EFR7670 exhaust housing selection RB26" I can seem to edit thr title on my Android.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
