im looking at upgrading the tubro on my 32 from an apexi ax53b70 to 1 of the 3 ---> gt3037s pro, gt3071r, gt3076r
looking for about 400rwhp with as little lag as posible what are the upsides and downsides of each turbo??? the 3037s is abt 1k more than the other 2 but its not rated as high ? am i missing sumthing? cheers fellas
https://www.sau.com.au/forums/topic/211464-gt3037s-pro-vs-gt3071r-vs-gt3076r/
You will need to give more info for anyone to advice you on this.
Little Lag...400rwhp.....?
What are your mods?
rb20det 2.2litre
Os Giken Cam Pullys
Tomei PROCAM Camshafts 256degree 8.5mm
Metal Head Gasket
Nismo 600cc Injectors
Tomei 2.2 Forged Pistons
12 Port Head
Port and Polish
Bosch 044 Fuel pump
3 1/2" Rsr Catback Exaust to 3" Downpipe
Apexi Power FC
Apexi AX53b70 -P25
Hybrid Frontmount 600x300x100
just wondering why the 3037s is alot more expensive when the others put out more hp :D
no you would be paying for the HKS combination
what ever spec, wheels, housing options etc are on the 3037s Pro there cannot be an equiv garrett unit
ie: you cant order a Garrett 3037s Pro as its a HKS locked item, and HKS have exclsuive rights to that combo
Garrett do many OEM style turbochargers but they also make turbochargers for HKS
any HKS combination that HKS come up with is made by Garrett but you can't buy it from Garrett, it must be from HKS
so its likely the 3037s is a well setup turbo for some specific engines, as HKS do the R&D and testing etc and say
we believe the combo is spot on for x.x litre engines and XYZ displacement or exhaust setup
so we've spent 10,000 hours and spent all the money testing out the combo, so you can have it with the HKS branding
Paul is right.
Basically a HKS turbo will spool a little faster and may make a little more power than any Garrett "equivalent". Whether the extra $'s is worth the minor gains is debatable.
With 300rwkw, the a 2.2ltr engine will always be laggy. The GT3076R (0.83A/R) MAY achieve your power goal, but is boarder-line. Also depends on your other bolt on pieces; such as exhaust manifold, intake plenum, throttle body, etc. and these parts need to be of good quality and not these ebay copy shit.
If the other two turbos have a lower power rating than the GT3076R, than don't bother considering them, if you're firm about having 300rwkw.
if your going to put a GT3xx series turbo on an rb20 invest in a good manifold and port as much as you can
the more exhaut gas flow you get out of it, the better, especially on the humble rb20
a well setup manifold, split pulse, external gate setup could be the different of say 500-600rpm difference in response if done correctly
The basic GT3037 cartridge is the same as a GT3076R cartridge - if the compressor wheel is 56 trim and most 3037's seem to be .
What you are paying for is low volume car specific housings that enhance a specific engines state of tune . Also generally these housings help with packaging a non std turbo on a production car .
HKS kits supply the 101 fiddly bits in one box , if its a Pro S kit they also supply their Micky mouse dump pipe .
It's possible sometimes to cheat price wise by buying 2nd hand HKS housings and bolting them onto a new Garrett cartridge .
For example if you found a 2nd hand 3037 Pro S turbine housing they fit straight on GT3076R cartridge .
I don't know about the RB22 and 400 Hp , obviously it can be done but most would take advantage of a better breathing and slightly larger RB25 . I think RB20 based engines are limited valve area wise so after appropriate cams I guess the boost pressure has to rise .
If I had to guess I'd say something along the lines of a GT2835 Pro S or a real GT3071R in 0.63 A/R could get you there with an aftermarket turbo .
There's always the GCG Hi Flow option and a choice of RB20 or RB25 or VG30 turbine housings .
Cheers A .
yeh disco potato the gt2835 is onli abit bigger than the turbo i have on there at the moment, its a redtop nics so the head flows alot better than other rb20s, ive looked around and the 3037s seems to b the way to go for the kinda power/response im looking at, theres a internaly stock rb20 no cams with a gt3037 in perth hitting 380 so i dont see a problem with me getting 400
Someone will know but I was under the impression that the R32 GTST top end was better than R31 gear . I believe that GTS-R aside the R32 engine made more power than than R31 versions did for the same capacity .
Affordable RB25 can do better than any of these .
Cheers A .
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
