im looking at upgrading the tubro on my 32 from an apexi ax53b70 to 1 of the 3 ---> gt3037s pro, gt3071r, gt3076r
looking for about 400rwhp with as little lag as posible what are the upsides and downsides of each turbo??? the 3037s is abt 1k more than the other 2 but its not rated as high ? am i missing sumthing? cheers fellas
https://www.sau.com.au/forums/topic/211464-gt3037s-pro-vs-gt3071r-vs-gt3076r/
You will need to give more info for anyone to advice you on this.
Little Lag...400rwhp.....?
What are your mods?
rb20det 2.2litre
Os Giken Cam Pullys
Tomei PROCAM Camshafts 256degree 8.5mm
Metal Head Gasket
Nismo 600cc Injectors
Tomei 2.2 Forged Pistons
12 Port Head
Port and Polish
Bosch 044 Fuel pump
3 1/2" Rsr Catback Exaust to 3" Downpipe
Apexi Power FC
Apexi AX53b70 -P25
Hybrid Frontmount 600x300x100
just wondering why the 3037s is alot more expensive when the others put out more hp :D
no you would be paying for the HKS combination
what ever spec, wheels, housing options etc are on the 3037s Pro there cannot be an equiv garrett unit
ie: you cant order a Garrett 3037s Pro as its a HKS locked item, and HKS have exclsuive rights to that combo
Garrett do many OEM style turbochargers but they also make turbochargers for HKS
any HKS combination that HKS come up with is made by Garrett but you can't buy it from Garrett, it must be from HKS
so its likely the 3037s is a well setup turbo for some specific engines, as HKS do the R&D and testing etc and say
we believe the combo is spot on for x.x litre engines and XYZ displacement or exhaust setup
so we've spent 10,000 hours and spent all the money testing out the combo, so you can have it with the HKS branding
Paul is right.
Basically a HKS turbo will spool a little faster and may make a little more power than any Garrett "equivalent". Whether the extra $'s is worth the minor gains is debatable.
With 300rwkw, the a 2.2ltr engine will always be laggy. The GT3076R (0.83A/R) MAY achieve your power goal, but is boarder-line. Also depends on your other bolt on pieces; such as exhaust manifold, intake plenum, throttle body, etc. and these parts need to be of good quality and not these ebay copy shit.
If the other two turbos have a lower power rating than the GT3076R, than don't bother considering them, if you're firm about having 300rwkw.
if your going to put a GT3xx series turbo on an rb20 invest in a good manifold and port as much as you can
the more exhaut gas flow you get out of it, the better, especially on the humble rb20
a well setup manifold, split pulse, external gate setup could be the different of say 500-600rpm difference in response if done correctly
The basic GT3037 cartridge is the same as a GT3076R cartridge - if the compressor wheel is 56 trim and most 3037's seem to be .
What you are paying for is low volume car specific housings that enhance a specific engines state of tune . Also generally these housings help with packaging a non std turbo on a production car .
HKS kits supply the 101 fiddly bits in one box , if its a Pro S kit they also supply their Micky mouse dump pipe .
It's possible sometimes to cheat price wise by buying 2nd hand HKS housings and bolting them onto a new Garrett cartridge .
For example if you found a 2nd hand 3037 Pro S turbine housing they fit straight on GT3076R cartridge .
I don't know about the RB22 and 400 Hp , obviously it can be done but most would take advantage of a better breathing and slightly larger RB25 . I think RB20 based engines are limited valve area wise so after appropriate cams I guess the boost pressure has to rise .
If I had to guess I'd say something along the lines of a GT2835 Pro S or a real GT3071R in 0.63 A/R could get you there with an aftermarket turbo .
There's always the GCG Hi Flow option and a choice of RB20 or RB25 or VG30 turbine housings .
Cheers A .
yeh disco potato the gt2835 is onli abit bigger than the turbo i have on there at the moment, its a redtop nics so the head flows alot better than other rb20s, ive looked around and the 3037s seems to b the way to go for the kinda power/response im looking at, theres a internaly stock rb20 no cams with a gt3037 in perth hitting 380 so i dont see a problem with me getting 400
Someone will know but I was under the impression that the R32 GTST top end was better than R31 gear . I believe that GTS-R aside the R32 engine made more power than than R31 versions did for the same capacity .
Affordable RB25 can do better than any of these .
Cheers A .
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
