so as most people know i was in an accident in november last year
i got the car back a little more then a month ago
on thursday night
11 pm
im driving down chapel street
in heavy heavy traffic
the car infront slows to a stop
i slow to a stop
i look in my rear view and i think wow that car isnt gonna stop
BANG
brand new clk 500 convertible rear ends me
i went apeshit at first then apologised to the guy saying sorry for loosing my cool
he said sorry and admitted he wasnt paying attention and takes the full blame
and half of chapel street had a good laugh
now my cars gonna be in another ********* shop again
anyone got estimates on how much work this is
im hoping no more then 2 weeks
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/
that doesnt look too bad
i had a hit like that ages ago, was gone for 1 week
1 week is reasonable, they might have to pull the boot out a bit
make sure you check if it aligns up properly when u get it back
and also make sure the boot opens / closes properly
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738790
That sucks!
Get it checked properly, you may need:
- rear bar skin (S1 and S2 are the same)
- rear bar reo
- rear tail lights (if mounts are broken or rear plastic cracked)
- rear "SKYLINE" fascia (if mounts are broken)
- repairs to rear quarters, boot lid, and tail gate.
May take time and a bit of work to do it properly. If it's not done right you'll keep having on going issues with water in your tail light indicators.
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738797
think youd be a lil more careful driving such a nice merc
these are good tips, thanks everyone. i dont really have any idea :S
im hoping to take it to "DT Panels"
they have been recommended from a friend.
hopefully they have easy access to all these parts
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738800
My call is as follows
Rear bar
Rear bar rio
Boot floor
Rear panel
Skyline fascia
Skyline badge
Trust me, I know about these bloody rear enders.
Will be off the road for about 2 week once all the parts are in stock.
BASS OUT
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3738831
Exactly the same thing, happened to me but I was at the lights!
My quote was
TOTAL $3,346.00
NOTES :
THIS QUOTE IS FOR VISUAL DAMAGE ONLY
FURTHER DAMAGE MAY BE FOUND ON DISMANTLE
PARTS PRICES SUBJECT TO CHANGE!
It looks almost exactly the same but just imagine, your big dent on the right!
Such a horrible feeling!
https://www.sau.com.au/forums/topic/211481-tuf-732s-rant/#findComment-3741570
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
