Lets say I have a complete automatic R33 RB25DET harness with the automatic ecu.
If I were to convert to 5 speed, would a 5 speed R33 RB25DET ecu plug directly into the automatic harness?
I know some of the auto wiring will not be used if so...
Just trying to figure out how hard it would be to convert a auto Rb25DET to 5 speed.
If anyone has any OTHER information too, please post. I'll be searching in the mean time as well.
Thanks.
EDIT: I also deleted and reposted this thread btw. The first one had some funny mistakes. I've been awake over 25 hours now. :tired:
Go to sleep man! LOL
I'll have to double check but I've got a funny feeling that an auto ECU will work fine with a manual gearbox but not vice versa. Don't quote me tho...
Is the mechanical side sorted? Ie flexplate swapped for flywheel???
Yes, the mechanical side would be all sorted out.
I've also been told the automatic ECU works fine. Anyone confirm that? I need to know ASAP because I have auto R33 engine swap on hold for me, yet it's an automatic.
BTW, I noticed in your post in my last thread that you said that all RB25DET's are RWD... what about the Stagea Wagon with the AWD RB25DET? Do they have those in aussie land?
Thanks btw. (getting ready to sleep hehe)
Guest RedLineGTR
In a automatic car their are two ecus
One is the main one and the other is for the auto trans.
The main ecu is tuned less richer than the manual ecu dont know why but it is. The Main ecu with work fine with a man or auto trans.
THe auto trans ecu is mainly for the auto box itself, the main ecu just communicates to the auto ecu.
The Connection to the main ecu and a manual ecu is the same and thier should not be a problem.
Cheers Rob
Redline, thank you VERY much. I had no idea and I understand completely now.
Will there be any check engine lights though?
And does anyone have any input on my engine pictures? It is an R33 RB25DET AWD right? Because sometimes other people looking at pictures can find different things. :D
This shit is hard to get info on in america. Thanks though.
You seem to be doing things a little bit the hard way, why didn't you just get a package RB25DEt engine/5 speed complete with ECU and wireing loom or better still an R33 front cut which would have given you some very useful extras.
Because it just didn't happen that way. One of the reasons is that this engine seems to be very clean. And it comes with everything a clip would except for the interior harness, cluster, etc.
Most clips I've seen don't come with intercooler piping or any of that shit, so I'm not really concerned about having a clip.
Plus, do you have any idea how hard it is to get RB25DET clips here in America? lol.... just try to find one from a reputable place. I searched high and low, almost every site I could find had a waiting list for RB25DET clips.
ONE site had them, but I would have to wait a loooooong time to have it imported. F that.
I'll get everything figured out..
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
