After selling my car after Sydney Auto salon final Battle I was a little undecided as to what to buy next. Not being able to make up my mind i bought a 2000 IS200 then proceeded to lower it 4 inches and put 20's on it. Car looked the goods but had no power at all.
After thinking for a while I have now bought a 2004 V35 Skyline. Car has around 15,000kms on it and is a premium with sunroof and Bose stereo. I am looking to take this car in another direction, although show / street is nice I want the Skyline to be a classy cruiser. Think I will leave the interior basically standard (few touches here and there) and just upgrade the stereo. Bigger wheels and lower it slightley.
Couldn't help myself, car is now at Prime Garage in Japan having a Trust exhaust fitted. This will give it a great note but keep it looking nice and stock.
Tell me what you guys think. Have already ordered a few little parts from the states such as clear lights, badges, infiniti scuff plates etc etc.
https://www.sau.com.au/forums/topic/211581-pictures-before-it-leaves/
thnking of eventually buying V35 4 door as a daily...what are you going to do about the stereo (stock) item..i know Jap ones do not have the entire FM band as the Aus sold radios, also any fix on Jap Satellite Navigation. i remember tread long time ago on SAU, and the guy could not find a way to convert them to Aussie MAPs..other than simply to use the screen as a monitor.
keep us upto date with your details...........
all the standard stereo will eventually come out as i see it as to much stuffing around and $$$ to get it all working. At the end of the day you only end up with a stock stereo.
I believe Chris Rodgers on here can get it working but wont be cheap to have full function NAV.
Mine will all be replaced with aftermarket items.
I hope you realised that during compliance the exhaust fitted by prime garage in japan must be removed and replaced with standard item, so I hope it's not a waste of your time and money getting it done over there before compliance is done...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
