Selling some stock engine parts left over from a build.
Stock Pistons
Stock Conrods
Stock Plenum
Stock Injectors
Stock Camshafts
Stock exhaust manifold
Series 2 coilpacks
Open to offers :D
Contact by PM.
https://www.sau.com.au/forums/topic/211596-rb-25det-engine-parts/
how much for the coil packs and they come with a harness what cond e.g how many Km's can i get pic's
Coilpacks do not come with a harness.They had no sign of break down when they were in the car,which was only the other day.
They have 70,000kms on them but are in great condition.
Price is $125 delivered.
Pistons look to be in good nick.No scrathes or grooves.Even the rings look good.Would need a good clean ofcoarse.
I would let them go for $200+post o.n.o
if u know were i could get a harness as i am going form series one loom and ecu to series 2 i will take them
  • 1 month later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
