Me,
i decided to get my shit together since its warm again, and get the stag back together
i wanna take it to the track for drifting at least 4 or 5 times this year.
BUT we will see what happens.
today:
Finished installing SAFC2
settings aer 4 in 4 out (i asked this question last year and noone knew)
Flushed the radiator, reset idle
put the back tire back on
installed bride Brix2 and rail
i ordered some Dmax rear TOe arms since i tweaked the rear subframe on a speedbump and i need it to get it aligned
Will be putting on 9j -17 front 10j -7 rear (hopefully)
I will alsp be transplanting my airbag setup from my nissan cedric to the stagea
its a kinda proprietary airbag that replaces the spring etc etc etc
anyways, stay tuned, pics and stuffs will follows
https://www.sau.com.au/forums/topic/211638-guess-whos-back/
i can
but its kinda expensive.
but i can.
I must have a rear spoiler, wing, or whatever. I am the only poor DB that does not have a rear spoiler.
HELP> EFFING HELP.,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,please
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3745165
hugh im contemplating getting rid of mine but wont know til i see the car up close... dont know if i like the idea of a spoiler on a wagon. But we'll see.
dont touch your autech kit!!!!!!:ermm: hands down best kit for the sexwagons imo :ermm:
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3746931
haha i like the Dayz rear wing over the big bulky one but im sorry... the rest of the autech kit pwns the DAYZ. Sits lower, more agressive...
We gotta get a photo shoot on carter! What year and colour is yours?
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3747337
I don't have one either, Hugh.
I'm guessing they're a massive help for keeping dirt and rain off the rear window, so Bobbeh I suggest you keep it on. My rear screen is always dirty after the rain, and it's a PITA.
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3747741
I bought an Autech wing years ago when i first bought my car, it was one of the first mods I did. Very awesome wing, makes the car stick out a lot more, and makes it easy to find in the car park.
I've got the DOLPHIN wing, which l'd say would stick out just as far (if not more) as the Autech, and def agree, makes finding the car in a carpark very easy!!
https://www.sau.com.au/forums/topic/211638-guess-whos-back/#findComment-3749503
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
