If you get an NA one driving past no-one will know the difference whether its turbo or not :(
I think parents who buy their kids turbo cars are irresponsible why dont they just give their son/daughter a loaded gun just to see what happens :)
Your parents are doing the right thing, honestly look into an Australian Delivered r31 if you want a skyline that much, your insurance will be alot cheaper cos its not an import plus it has a bigger engine :merli:
  • Replies 193
Posted Images
no it doesnt im probably going to put it in my parents names because it would be cheaper
forgive me if i am wrong, but i was under the impression that insurance companies required import cars whether turbo or NA to be insured under the youngest driver...i know just car require this. so even if its under your parents name and you are in an accident they wont cover you. And we all know insurance companies will do anything to take our money when it comes to premiums, but when it comes to pay outs they will find anything that may void your policy.
goodluck with that all champ!
my first car was a tg gemini that i paid 1500 for, it wasnt the nicest looking car but was extremely reliable.
in hindsight it was the best option for me because i literally killed that car, it copped huge mechanical abuse then got stacked in the end.
imo, buy something cheap to learn in, save some cash, buy turbo car later.
i'm just gonna say your dad is a smart cookie
if i had a 17yo kid i wouldn't let them get a "fast" car.
i think you should think about getting something that isn't so fast
and when you get more driving experience then go for it.
if you get the insurance put in your parents name make sure your name is on there aswel
Edited by pokie
most insurance companies would be a little suspect of a 55 year old man getting a R32 gtst that made in 1990+ (my thoughts only)
and i you put your name as driver #2 would has at a guess that your the primary driver (again my thoughts out aloud)
Get an Aussie R31.... that was my first car. Sure, theyre not as pretty as more modern lines, but they handle well, are cheap to run, cheap to fix, and the 3 lt engine is nothing to sniff at
-D
yeh i kind of agree, i bought my car when i was 16, didnt have any real issues with it, but i think when i look at some of my mates, i can see why people would be hesitant to get their kid a fast car, and u just dont know what kind of a driver ur kid is going to be.
riiiite
whats so funny about the pulsar, probably go harder than you can handle anyway.
maybe point out the positive sides of a skyline, advanced suspension etc. convince him into letting you get one. after all, he doesnt want you getting one because hes scared your going to be an idiot and kill yourself on the road.
turbo'd cars only go fast when the person behind the wheel lets them...
Pulsar GTiR (4wd sr20det) from memory runs 1/4 in the 12's....now thats pretty fkn quick, especially for a stock car.
If i were you dude, id get an r33 gts4 (n/a) and when u get off ur Ps, stick and rb30det in it :blink:. mmmm....
whats wrong with 17 and owning a turbo car ^_^ just because some didnt have one when they were 17 i bet if u were 17 and ur parents offered you would definately take it! i know i did lol..
someone sounds like they are spoilt :blink:
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
