  • Replies 54
don't get a 300zx! hold our for the r33 - they are far superior! the 300zx's are cops of cars - heavy, weak engines, hard to work on (have u seen the engine bay??) not to mention lack of seating in the rear (even in the 2+2) i know they're cheaper and more power, but you'll have way more mechanical problems with it and the power only makes up for the weight.
seriously the 33 is a great car i haven't had a problem with mine in a year and a half - but if u really want a 300zx, wait til 1st jan next yr and get an '89 for like $7.5k - check out www.prestigemotorsport.com.au and go to stock. (not affiliated)
fair nuff thats pretty quick - the r33 na does 7.3 (manual) stock. Tho with a small amount of mods (exhaust & pod filter mainly (bout $400), extractors ($350), hi flo cat ($300) & super afc II ($550) - if ur keen) u'd easily break that time and have what i consider to be a nicer/more practical car -
but that's just my 2 c ;)
did i mention that in a stock locking r33 i've never been pulled over by the cops in 1.5 years with p plates up? :) dunno how many 300s wouldnt get pulled over ?
hey i just realised i know a guy selling a r33 na 5spd gunmetal grey type m (front bar & skirts) - other than that stock i think - maybe exhaust - i don't know him that well tho... he hasn't advertised his car but he's got a sticker up - he might want slightly higher tho like 14k... i'll check it out
actually i heard he might wanna keep it cos he got a call from a some hot chick who saw him in his car and called the for sale number and now hes r&%ting her!!! hahahaha
naiwiboo is right, next year you can get a sweet '89 model twin-turbo 300 (which is the same shape as the '90, '91, '92 model etc.) for sweet f.a. And n/a's for even less. If you're serious about a 300, you might as well wait another 6 months and import an '89 model and get in under the 15 year rule. Believe me, you'll appreciate the savings and so will your wallet!
Hey sxy R33, I know ya did your homework, and you are right that's about the right price, but at the moment there is no compliance :D so if u import now, the car won't be going on the road any time soon cos the good people in our government are too busy walking around with their thumbs jammed firmly up their as...
where? In melbourne? If so, can you give me some names cos my guy in Melbourne said they he couldn't get any plates for me or get any cars complied there and then brought here. I'd really appreciate dude, cos if he's lying to me, I wanna know + means I can finally get the Supra we've had sitting in da mechanics for the last 3 months finally on the road! :D
cheers
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
