  • Replies 46
Posted Images
from my post in the other thread:
the only cruise that was offered on the V35 was the active cruise in the sedans
i posted a pic in another thread.. will attach it again.. the car has an IR display on the front grille and has different lights in the instrument cluster..
the cruise from the G35 is a normal cruise system from what i have read on G35driver
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3754622
have done aftermarket on them - about to try OE. that will happen on monday -wed this week. if all goes accordingly and it works I'll publish the specs.
what EXACTLY is your car? model,trim,trans,engine?
what I am working on only suits a limited range of cars. (2001-2004) it is NOT the one pictured above.
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3754920
2003 V35 350GT premium automatic coupe
Everything is stock standard
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3755520
trust me you DO NOT want to see the car right now. figured I'd make a start on it.
quick notes- no lights on dash- checked that. positions are there though.
brake switch - non existant.
cruise wiring - non existant.
I'll chase a brake switch tomorrow.
cruise wiring is going to require a bit of 'thought' . considering shielded cable on it for noise sake.
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3757253
ok brake switch is in place (modded one cannot get the correct one so I'm using a N16 one with a relay for polarity.)
cruise switch is wired and checked- have ladder voltages when pressing buttons.
now for a test run. all voltages check out.
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3759876
no dice ;)
usure which part needs changing via software or hardware but in standard form it don't work. need a US consult 2 I figure. for sh1ts I'm going to run past village nissan sometime tomorrow and try theirs.
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3759903
damn.. good luck with village nissan - hope they can offer some help
what do you think the issue is?
something else in the G35 that is needed to control it?
if it fails, could the steering buttons be hooked up to an aftermarket cruise control so that it operates using the buttons, but controls the car like something that is known to work?
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3759938
I have the ECU in my lap now googling the part number. put a request to a mate of mine in the states for a G35 ECU and G35 cluster for 2003 spec. I so want to crack WHY this wont go. looking at it the whole thing MUST come down to firmware. there is nothing else needed - the whole lot dumps literally into the ECU and gets driven from there.
option 2 I though about but I think the ladder voltage is different to teh ones I use. that is a last resort :glare:
https://www.sau.com.au/forums/topic/212498-cruise-control/#findComment-3759982
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
