  • Replies 46
Posted Images
No i don't need spare audio buttons :P
what I was thinking is to get the assy from US, cost about $60-80 shipped not quite sure exact shipping cost yet, and
see if a local company like Autron can wire it to their generic vacuum cruise control unit.
chris, do you want the spare audio (left hand side of steering wheel) buttons you left in my car?
i obviously have no use for them!
I do.
Is that SCS you mean the same with either the SCS-4342 or SCS-3342 ?
3342 - electric. van version is a pain on those cars.
best if I talk you through it. you have the buttons and diagrams to wire it? ring me on monday. I'm away at my parents until then (I'm on a 28k dialup link to my shop server right now.)
No, haven't got the buttons yet, just ordered last night, was just warming up the engine n looking at the panel and tried to tweak it but won't budge. only saw two caps on both side of the steering wheel cowl which reveals 2 bolts on both side but not sure if that's where I am suppose to start.
will ring you after it arrives, possibly after the long weekend next week.
ok:
undo battery negative lead.(remember to reset your TV.)
remove cover caps from side of steering wheel.
remove two tamperproof (think they are t30)
remove air bag and pop clip out of the bag of the plug
pull plug out of air bag and set that aside.
disconnect horn wire (yellow wire that runs to steel frame.)
undo the two torx bolts that are now visible (t30 or t35) and remove assembly, careful with springs
undo 19mm nut but do not take it off.
unplug steering controls and send to me :P
wriggle wheel until it comes off.
remove 19mm nut and remove
remove 4 phillips screws and remove the rear plastic shroud, this is clipped on.
remove 4 screws from SWC and blank panel.
when you put it back together route the cruise wiring across the top of the rear cover so it doesn't foul on the horn assembly.
ring me if you get lost.
unplug steering controls and send to me :)
thank's for the instruction, didn't think it'll be that complicated just to get to the stupid blank panel :P
which one? the blank one or the new cruise control? do you need to modify anything before it will work?
also you said the harness is already pre-wired inside the steering wheel column to connect to the cruise buttons, is that right?
thank's for the instruction, didn't think it'll be that complicated just to get to the stupid blank panel :)
yep its a fun job. I want your old radio controls :) harness is wired through the clockspring but terminates on the wheel side inside the column shroud - you need the wiring diagram to pin it out and get the wiring through.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
