Hey
I installed a set of GTR injectors onto my RB20 and am just wondering if someone can tell me how to correct the Power FC so I can drive the car to the tuners?
What settings do I need to go into and what values do I need to put in or even how to calculate the correction and I will work it out my self
Can I just go into the INJ correction section on the Power FC and put the values down from there?
Standard injectors are 270cc and GTR injectors are 440cc
Any help would be appreciated
Can remember the way of the top of my head but it is setting> then fuel correction or somthing you will have to have a look. Your old injectors are 61.3% the size of your new ones so pull all the injectors down by 30% to be safe and it should be ok if you dont have to drive too far just dont flog it NO BOOST, just keep an eye on you knock level.
Good luck
Good luck
Thanks man, I will give that a try
what sort of powerfc do you have?
Its an AP engineering Power FC to suit RB20DET with hand commander
Okay I had a look and this is what I got according to your table
Old SIZE / New Size = Correction
260cc / 444cc = 58.558%
New Latency - Old Latency = Latency Correction
0.772msec - 0.89ms = -0.118
What settings do I got into on the Power FC to enter these values?
I dont know if its similar, but using my safc2 i calculated -31% up to about 5500rpm where i went -29% to be safe, and guess what first run on the dyno 12;1 afrs to 7800rpm.. bit of a fluke really.
I think you will be safe tuning it down at least -25% as the flow difference is like 38% more compared to 270cc.
Cheers
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
