Have answers to all questions except which timing light do you recomend for me to use on my Stag. Dont really want to spend big bucks as Ill probably only use it once or twice!
Hi All. Have a couple of questions... Just wondering where I check the level of the transmision fluid on a '97 RS Four?
Also Im approaching the 100,000 so I will be in need of a timing belt change, How much should i i be willing to pay? Also If someone had the part number for the belt that would be great.
I've read the how to's on doing the timing belt change and it doesnt seem to hard, if its going to be overly expensive Ill probably have a crack at it with a mate.
Thanks in advance,
Chris
Edited by kidafa
https://www.sau.com.au/forums/topic/212800-timing-beltwhich-timing-light/
Changing the belt is really easy. We recently had a BBQ here in WA and 3 of us got it changed no problems. Follow the step by step guides you will find on here (especially the one by SydneyKid) and you can't go wrong
Have a look at the classifieds - There are quite a few that sell the originals as well as after market ones such as Gates belt kits etc. The only problem I could see with the Gates kits is they don't include fan belt, alternator belt etc etc but they do include stuff like front crank seals (that you can't use because you need to pull the sump off to fit them and to do that you need to get the engine out)
Oh, and the trans fluid level is checked on the dipstick, the same as any other auto.
ROFL!!! Behind the rocker cover up against the firewall
I must have spent about 3 hours staring at the engine bay, and my missus (the biggest mechanical n00b in the history of n00bness) was the one that finally found it.
Keep looking, it is there.
You don't really need anything flash as far as a timing light goes, as long as you can be assured that it's a reliable unit. I couldn't really recommend a specific light to you ('soc I've got no idea what's out there in the market), but for convenience's sake, try and source one that is self-powered (using batteries) so it's two less wires to get tangled up in the engine bay when you do check the timing.
Its in the sticky of DIYS and FIYS at the top of the page....
Here I am looking for an R33 guide, it's hidden in the Stagea section, who would have thunk it.
I'm going to give mine a go, I think I have enough mechanical skills after 3 years of modifying the Stagea to know what I'm doing. Just need to borrow a timing light from my brother in law and I'm set.
Would people recommend replacing the water pump after 200,000km? it doesn't seem to leak, but I'm not sure what condition the bearings/shaft are in. also the idler and tensioner pulleys, should they be replaced at 200,000km?
<snip>...... for convenience's sake, try and source one that is self-powered (using batteries) so it's two less wires to get tangled up in the engine bay when you do check the timing.
+11ty - If you have ever had a fan grab hold of the power leads of a timing light right in the middle of setting the timing on a grumpy old 308 (dizzy at the back of the engine, not a fun task at the best of times...) then you would join me in celebrating Nicks wisdom :D
Using the SK method I've done two S13, CA18s and my Stag. Never used a timing light at all. It just took the ECU a minute or two to realise.
might aswell do the waterpump while you have it stripped down, source rb30 easy to get and cheap,
goodluck.
AFAIK, they're exactly the same Leshy. That part of the block should be identical no matter which RB engine you have.
Also, I believe the N1 water pump is the best one to get - the blades have a different shape and backing which reduces cavitation.
Reading more into Timing adjusting in the forums... Reading a fair few post of people saying their lights read double the actual timing? Some people are saying this is becuase how the light is hooked up to the car.
Ive establishedi should purchase one that is externally powered, but what sort of conection should it use to connect to the car?
Can you post a link? Because i am not sure what you mean by "double" the timing.
Strange, I've never seen that, although it has been a while since I've needed to check the timing on anything. I have noticed that our self-powered one has a direction mark on it so that when you attach it to the spark plug lead (or whatever the RB25 uses in its place, seeing as it has coil-on-plug), that the spark plug is on one side and the "direction" of spark is a certain way, if that makes sense... :/
You shouldn't really need to check your timing afterwards, kidafa - just make sure that when you remove the belt that the timing gears (and therefore the camshafts) don't move, Make suer BEFORE you remove the belt that the crank and timing gears are all at TDC.
An example of what i mentioned: taken from:http://www.skylinesaustralia.com/forums/Timing-Marks-t211594.html&hl=timing+light
you can use the loop but some timing guns have the problem of reading double, i have a super cheap 50 buck jobbie and it reads doulble the actual setting so the gun lights up at 30 deg but its actually at 15 deg
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
