  • Replies 456
Posted Images
I got these for my 35 :)
I'm finally getting a new gearbox for my V35.....and while waiting for the mechanic to pull the old box out, I sat in his R35.... where I was presented with 3 'R' mode buttons...for suspension setting, pedicure, blowjob.
Is that the 'R MODE' you're getting at??...if so...koooooool!!!!
Yep - those buttons are why I got the plates :cool:
Hi guyz!!~!
Im like new here so hi lolz... I want to use the buttonz in mah skylinez. Especially tha one for the blowjob modez. Can you tell me wheres I can find its!?!?
hahaha...yep....middle lower center dash.......look for the universal symbol for 'head job'....the button next to tissue wipers.
those '1' plates are on a silver E55, it's owned by Peter Bartels ... I live in the same apartment building (see it parked downstairs all the time)
He took me for a spin round the block in his Porsche about 20 years ago. There was no funny business...
  • 7 months later...
person at my work owns the RIPGTR wrx.
STI badges all over the car, roof scoop! and its an auto?
i have been told, not that i believe it
that an auto wrx is faster than a manual
and they give you wiplash when they change gear ha ha
i finally saw the gtr killer but i have a gts so i didnt want to represent :P
Yeah, saw that Silver Supra [GTRKLR] parked near Lygon in Carlton last week.
For $2300 you could have
DUI
funny but would attract a lot of attention i'd say
LOL not as much as [sTOLEN]
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
