  NXTIME said:
I'm sure Ben has pitched a few tents in the back of that thing...
I've carried many types of boxes in the back of that van :starwars:
Was a great day, my van smelt like methanol the whole way to work - perfect way to wakeup at 4am this morning.
  • Replies 114
  benm said:
Of course! Must have had atleast a dozen people pull me up on the stickers by midday today...
love the sig. Ben...well done.
but...on the 8.07 run you took off so quick down the track you forgot to wait for the rope man. If only you could get your vechicle to take off that quick when you are driving on the other side of the wall. :D
Oh I waited, you were too busy wiping up ur mess!
You should have seen Marks reaction at the top end, I yelled out 8.07 out my van window and he jumped into the air. On the way up it was "yessss" on the way down it was "arghh noooo" so close yet so far from a 7.
Then their was some hoon in a datto 1600 pull up trying to pick him up like it was Kings Cross on a friday night!
You're memory is a bit fuzzy, Ben. The Datto was there long before the white van. :D I drove around the bend in the deep beeping and yelling and waving and I could see Mark saying, "Was it? Did I? What was it?"
So close yet so far. Video is uploading now.
how did i know that ben was talking about you?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
