hey guys ive got stock suspension at the moment and pushing around 190rwkw... so would like to looka t handling a bit now, ive removed my hicas fuse because the hicas was pulling me seriously to the left on high acceleration/high speed which was a worry and since i removed the fuse its been fine... i am planning on getting a lock bar soon for that.. but also just wondering with strut bars.. can i just get the cheapest one i can find or are adjustable/better brands really worth the extra ? for my suspensioin i am currently looking into going conia shocks and springs all around
cheers
https://www.sau.com.au/forums/topic/21314-strut-bars-in-r33-gtst/
strut bars arent really nescesary (spelling) but if u did get one, maybe an aluminium one or sumthing that is not adjustable. expensive ones arent really worth the extra unless its frotrack use mainly. The suspension setup sounds good if ur thinking of koni, otherwise i dont know wat conia is :D
Before I put sways on my car, I put strut bars front and rear and hardly noticed any difference in the car. From my understanding strut bars increase the rigidy of the chassis.
On my WRX when I put one in the front I noticed a slightly better turn in on corner entry though body roll didn't change. Thus you can conclude that the Skylines have a better chassis to start off with which is why there is little difference.
The biggest improvement was the sway bars cause the car is much more sharper on entry and the ammount of roll is reduced.
Strut bars go over the engine bay. Sway bars are underneath the car.
Plus you get more rice factor out of strut bars! :)
I think sways are about 250 or so. If it's for a RWD car you probably only need one for the front suspension. If you want to go do track days then front and rear.
i found a slight difference when i fitted the strut bar in my engine bay, not alot mind u but a lil bit, picked one up for $160 gives it a bit more of a performance look too i reckon...
sway bars not too sure how much there costing atm.
cheers
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
