Hey guys
as the tittle suggests i need some help/advice on my little car trouble.....i have a r33 s1 and lately when i start it in the morning or when its cold the stutters for about 10-20 seconds or so and then idles properly.....and yes i have a load of fuel in there.....and once its warm it runs normal with all the power.....so i was just wondering what is going on there?????
thanks
Krish
https://www.sau.com.au/forums/topic/213234-little-car-trouble/
I too am having the same thing happen only in the last week in my series 2, thought it may have been my fuel pump or filter so took it to get dynoed on monday and he said everything is running perfectly with no error codes.
When its warm no problems, only when its cold it will idle low amd eventualty the engine drags it up.
I looked through the forums and i think someone was saying something about cold start sensor or valve, does anyone know anything about this or have any other thoughts??
yeah when you cold start it sounds like the engine is going to die off but after a few seconds it drags itself up to normal idle......well i figured that it cant be the fuel filter as after it has warmed up it runs brilliantly.....so wtf is wrong anyone please....
Yea its your idler thing me and Luke just cleaned mine
krishy i find it hard to believe your idle isnt moving
iv'e got amother issue also after my car has been on for a little while after not being on for ages 5 mins into driving it falls over sometimes i can back off and on and it comes good alot of the time i have to pull over wait 1min and restart car and them it's all good
after the cold start the revs jump up down up and down.....but once its nice and warm it just sits at either 1000rpm or sometimes around 1000-1500rpm....it only jumps up to 1500 from 1000 rpm if i have my fan and other things on at the same time.....but now i come to think of it lately it has been sort of jumpy.....not really noticeable though.....so i will take the baby out for a spin after work and see how it goes from there....fill you all in about it tomorrow
Edited by Krishy
Rush: thats the one, IAC AAC number of different names with the same function.
Krishy, its quite possible the buildup prevents the initial movements of the IAC that's why its bad when cold. Once the car warms up and it has broken the "seal" - less noticable. once cools down again, same issue. Try it and see, cant do any harm giving it a clean anyway ;)
yeah i think i will have to give this a go......well it wont hurt really.....but i am not a very mechanically minded person so slightly hesitant on doing this....anyone with experience....there is a carton in it for ya
I'm free this Sat arvo and I wanna do the same thing. I'll be the guinea pig! :P
Forget what Madaz says ... I'll take the carton! :woot:
j/k
Just did my AAC then, was filthy, went through half a box of ear buds. Its not hard krishy, just a prick of a spot to get into. Started it up dead cold and seemed to run normal. Will let it cool right down again and try again a few times but seems to have fixed it so far.
Thanks fellas for all ur help. Let us know how it goes krishy
hey just wondering do you start the car up when you jump in.... or do you get in turn to 1 click back from run and wait for the fuel pump and injectors fill as sometimes they can be a bit dry then starting it up with no fuel in the injectors makes the car stutter for a few seconds.
juest a suggestion.... cheers... michael
also another reason this could happen would be if you have aftermarket ecu and the cold start isnt setup properly, my old 31 coupe used to die a few times on cold mornings before it would run just cause the cold start hadnt been setup on the microtech, probly isnt in this case but just another thing for people to note if they have this issue.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
