These set of coilovers are quite near new and in perfect working conditions ,
specs are :F 8kg / R 6kg
10,000 kms on them. they perfrect for street use . alot of ppl go and pay extra for camber tops and they never go in the races or anything so for mainly street use why waste extra $$$ for nothing !!!
pick up only or accept paypal as well.
Vehicle: R32 Gtst
Condition:very very good
Price:$750 ---> now $650
Contact: 0449665288
Edited by kurd_boi
https://www.sau.com.au/forums/topic/213481-r32-cusco-zero-1-coilover-set/
height adjustable are they mate? do you adjust the height with a c spanner whatever its called?
yes of course they are
spanners not included but ya can grab em for $20 from peddars
Edited by kurd_boi
sorry i dont think the zero 1 is Damper adjustable just ride height, The zero 2 is height and damper adjustable and the Zero2R has an inverted shock.
yes right i only meant to refer to the height adj
this is cheaps guys why arent yous buying me :blink:
Edited by kurd_boi
  • 3 years later...
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
