  • Replies 110
Great work with your build. Its refreshing to see someone sharing their assembly process with such detail.
Now when someone has RB26/30 buld questions they can just come to your thread instead of being flamed for not using the search button (which produces more BS than real useful information).
Do you have a purpose in mind for the car? Drag, street, track or all of the above?
Hi, just wondering if you have felt the clutch yet, im looking at having to remove the clutch booster to fit my plenum. Also why did you go for the integra master cylinder instead of the original one?Was it due to the fact the stocker doesn't have provision for a fork?
the clutch feels fine..i don't feel a different without the booster
thanks ....
i will keep the updates going ..when i am back in canada..
i am currently traveling around tokyo and HK !
  • 3 weeks later...
more updates !
it's finally looking lik a car now!
with fuel system completed !!!
starting from the back
fuel lines protector guard !
fuel line holder
at the front
dash completed ! glued the back together !
heat sheild for turbo and down pipe
hand made wrap!
HKS to4Z turbo bell mouth machined to fit with my T78 greddy turbo
since the engine is 3inches taller...we made this angle down so i can use my billion rad hose instead of getting soemthing else
polished PS tank
so more work done @ Keep Performance Lab today ~
i must say these guys are so Good with Wires !!!
again keeping it clean is always on the top of the minds. so organizing the wires were very important as it is easier to work on as well as it looks alot nicer.
here are some pictures from today
back of the kill switch mounted where the rear wiper used to be
attention to details
Keep Performance lab even got the Bolts on a OLD HKS coilover GOLD PLATED
my external oil pickup as well as both the external head oil drain and turbo oil drain (had to reuse some old fittings as i don't have time to get new one anodize gold)
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
