  • Replies 110
Xmas 2008 update !!!
after spending another $2500......i got another RB30 rebuild kit. from spool imports from australia.
very good guy to work with !! and he's very helpful.
here are the detail pic of the cf items i got..i must say....using carbon kevlar (yellow) is very hard to do cuz u can see the blemish very easy....like un even weaves
A picture tells a thousand words
  • 2 months later...
here's news
oil pump blew up on the dyno @ idunno what rpm but the highest we had was 7000rpm but the end result was bend rods, need new bearings..etc..
rebuild again...
sorry to bring up the sour memories but did u run a oil pump crank collar with your n1 oil pump?
do u know the reason why this oil pump let go? ive spoken to 3 mechanics who actually vouch for the n1 oil pump 'if' the crank collar is fitted
  • 5 months later...
Do you have a web site or the company name of where you got the carbon kevlar overlay done? It looks insane
Don't know where you are located but if you look at them parts it is simply carbon wrap (original plastic is under). can do it yourself. carbon sheet is about $70 a square meter then you need some resin and patience.
Or you can buy the fibreglass sheeting that has the same weave as carbon and dye it black then use it :P (about $7 a square meter)
it looks cool but unless you are going to make a mould and make a part completely out of carbon there is no actual benefit to be had apart from the looks...
Edited by GT-RZ
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
