Hello,
Dont want to sound ignorant, but what size are the size of the rotors on the M35 Stagea, looking to upgrade the brakes.
Are they the same as the V35 Skylines.
If you know can you please post up all specs.
Jules
Hi Jules
I do not know the size of the rotor but they are the same as the V35. The part numbers are the same. The brake pads are also the same as the V35/G35. (confirmed this with Ben).
I am looking at getting some Hawk brake pads from the US for front and rear. Just waiting to confirm the cost of rear pads.
Cheers
Andy
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3772848
Hi Jules
Cheers
Andy
Hello,
Ok that should make it easier then, I was looking at these from A & B Motor sports, who are conveniently located in Brookvale.
http://www.aandbmotorsports.com/brake.html
I like the looks of the 6 & 8 Pot Brakes. The brakes on the M35 Stagea are less than desirable, I reckon some 8 pots would help a bit.....LOL
Jules
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3773992
Hello,
Jules
I noticed they only listed the G35 from 2006 on. Lets hope it still works.
We will have to meet up some time. I will be working in Cromer from May.
Cheers
Andy
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3774056
Cheers
Andy
Hello,
I just spoke to them and he told me he noticed a huge difference with his R33 Skyline with their brakes. He suggested 8 Pots for the front and 6's for the rear. They are designed to run off the stock OEM master cylinder. Prices were
$2,200.00 for front 8 Pots - 330mm rotors
$2,300.00 for rear 6 pots - 330mm rotors
Excludes fitting, they could fit them for about $200'ish if purchased directly through them.
Jules
Edited by Paramour
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3774873
Below is the part numbers on the actual pad for the M35 Stagea VQ25DET and the various non Brembo brakes on the V35 Skyline, their is a bit of a difference on sum.
M35 Stagea
Part no. on actual front pads: NISSAN HITACHI HP63H FF
Part no. on actual rear pads: NISSAN AK AP66 FF
Part no. on actual rear pads: NISSAN AK AP55 FF
V35 Skyline
Part no. on actual front pads: HITACHI HP66H GG
Part no. on actual front pads: HITACHI HP63H FF
Part no. on actual front pads: TEXTAR T4146 FF 41 (Replacement Part No. 41060-AM892)
Part no. on actual rear pads: AK-FF AP63H
Part no. on actual rear pads: AK-FF AP55
Part no. on actual rear pads: AK-FF AP61H (Replacement Part No. 44060-AM485)
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3776643
  • 2 months later...
Does any one know could the brembos from a v35gt be fitted to an NM35 stagea
Wish I could help you. Maybe ring Ben or Tony at Northshore Prestige in Sydney. Cannot see why they wouldn't though.
BTW. If thats your car in your profile you need to stick more pic's up. Look's F...king awsome.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3927061
OK. Today I thought I would go through our old R32 GTR bit's to see what fit's and what doesn't. So here's what I came up with. Found an old set of front R32 GTR 4 Spot calipers measured them up and they fit. Small issue with some spacers to be made up(cost about $15 for the spacers) but everything else will fit perfectly. So if you want a cheap upgrade get you hands on a set of front R32 GTR calipers and you done.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3944323
Mmmmmmmmmm....Very interesting......
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3945513
The front Brembos off 350Z, V35 Skylines will fit without any mods at all. I trial fitted them when I took off my Brembos from the Zed.
The rears im not sure 100% but my guess is that it's possible.
For a good used complete set of Brembos, you're looking at about $2500-2800 including calipers, rotors and pads. Im considering upgrading the brakes next.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3969160
Fitted up the R32 GTR callipers tonight. Pretty easy job....you will however need to cut and linnish the bolt going into the caliper from the brake line.
The other thing you will need is rotor's that have a minimum thickness of 30mm(M35's are 24mm).....hopefully sorting some R32 GTR rotors tomorrow.
P.S. I will post up step by step once I have everything 100% finished....looking like a very cheap option still.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3982592
R32 GTR Brake setup done.
Parts needed:
*R32 Rotors
*Pads
*1 LT of brake fluid
*4 Spaced washers to go around the outside of the bolts going through the suspension arm and bolting to the caliper
Parts needed to be modified
* Remove or cut off the dust guard on the inside of the rotor.(if you have a nibbler this is a fairly quick job to cut off)
* Take about 1mm off the brake line bolt going into the caliper...or buy a new shorter one.
All up cost for everything was:
*$280 for the calipers to get rebuilt(or whatever your cost is for new ones)
*$80 for the Pad's
*$300 for brand new rotors
*$20 for Brake fluid
*$45 for Spacer washers to be made
*About 2 hours worth of your time
P.S. The only thing I have not yet tested is that the standard wheel and space saver fits...will let you know soon.
Edited by Jetwreck
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3988323
I guess the important question is, how does it feel and perform......compared to stock...
If I was to compare them with the new Nismo pads I had just put in the standard calipers its a definite improvement....lots more feel through the brake peddle.....mind you I have not had a good stand on them yet.
https://www.sau.com.au/forums/topic/213586-m35-brakes/#findComment-3989072
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
