Yea guys it was a great day there. Thanks to all the helpers who made it possible.
If you want to get into track days, sign up at: www.TimeAttack.com.au on the Join Now page. Also check the Events section of the QLD forum and the motorsport section of the main forum.
Next Time Attack day is May 14. Time Attack Series Round in the morning and normal track day in the afternoon with a beginners group that will get extra tutorials in the briefing room and track side tutoring.
Sorry to see you have to retire to back pain Geoff.
Paul
Paul
IS THERE Any website to see the lap times for the Day at lake side ?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
