Yea guys it was a great day there. Thanks to all the helpers who made it possible.
If you want to get into track days, sign up at: www.TimeAttack.com.au on the Join Now page. Also check the Events section of the QLD forum and the motorsport section of the main forum.
Next Time Attack day is May 14. Time Attack Series Round in the morning and normal track day in the afternoon with a beginners group that will get extra tutorials in the briefing room and track side tutoring.
Sorry to see you have to retire to back pain Geoff.
Paul
Paul
IS THERE Any website to see the lap times for the Day at lake side ?
