in need of cash so thought id sell a few things ive got floating around.... do not want to post incase damage occurs would prefer pickup = reason for low price
Item:Large front mount intercooler 300x600x115 (VERY LARGE)
Age:unsure
Condition:brand new
Price:$350 FIRM
To Fit: (What car) ANY. mounting points to suit r32-33-34 GTR but can be made to fit anything
Contact: via pm
Comments:
Item:mines ecu
Age:unsure
Condition:good
Price:$200 FIRM
To Fit: (What car) r32 GTR skyline
Contact:via pm
Comments: selling because i bough apexi power fc
Item:braided brake lines
Age:unsure
Condition:good
Price:$75 negotiable
To Fit: (What car) bnr32, may fit others
Contact:via pm
Comments: taken off my car during compliance
will sell all 3 together for $500
(edit) just added 2 rc cars to the list a big chunky offroader 4wd single speed and an r34 gtr chell on a 4wd 2 speed racer(does approx 95 km/h) both are near new with only doing approx 4 hours each.. retail $950 each selling for $350 each.
also turbosmart blow off valve mount for r32gtst maybe 33 and gfb blowoffvalve(needs new spring) both brand new $60 for both
Edited by jenkies
Age:unsure
Condition:brand new
Price:$350 FIRM
Contact: via pm
Comments:
Item:mines ecu
Age:unsure
Condition:good
Price:$200 FIRM
Contact:via pm
Age:unsure
Condition:good
Contact:via pm
If the front mount is a straight bolt up i'll take it, thanks.
not too sure.... i bought it off a sau member a few months ago.... came in a blank box and there arent any markings on it.... bracket mounts and end tanks are to suit gtr.... its a little thick for the sort of power im puting out
c'mon make me an offer.. im even down for trades of interest.... after dump pipes and/or front pipe... or anything else
heya if u just chuck the braided lines in a box and send it to sydney i'll take em. i know u sed pickup only but make an exception?..pweeezzz!!!!
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
