that is way to high, it should read 4 and then drop to bar below that once warm, make sure u have the right amount of oil
checked the oil. its slighty above the max mark but 1-2mm.
btw im using full synthetic oil.. i think 60/10.. (Think)
could that be the problem?
https://www.sau.com.au/forums/topic/214069-oil-pressure/#findComment-3779969
That sounds like the oil is too thick which is making the pressure very high when it is cold.
Skylines like oil in the 10-40 or 7.5-40 range only and synthetic if you can afford it. The best is Motul Chrono 10-40 but it is nearly $100 for 4 litres.
https://www.sau.com.au/forums/topic/214069-oil-pressure/#findComment-3781188
  • 1 month later...
can anyone confirm with me the dodgy oil pressure gauge on my S2 r33? I have a fresh built motor with the lot internaly but about half an hour nto my first outing at the track the indicators went funny and the oil pressure now sits on a big scary 0 at idle but isnt making any bad sounds (knocking as it should if the pressure was correct).
When I rev it it only gets to just above the first bar on the gauge but all was working perfect before the indicators went oh and no fuse's are blown. also the oil pump is a tomei item for a RB26 to fit my 26 crank. waiting for my oil filter spacer to come so I can fit my mechanical oil pressure gauge.
any one have a similar problem with the R33 S2 oil pressure gauge?
https://www.sau.com.au/forums/topic/214069-oil-pressure/#findComment-3899329
erm ...
Cold start.. esp winter mornings... its normal for ur pressure to reach around 7 for the frist few mintues of driving....
After its warmed it will drop down ...
Idle around 2.
And when u drive should b around 3.5.
I have the offical figures in my room... i printed out the service manual.
Edited by br3ndan
https://www.sau.com.au/forums/topic/214069-oil-pressure/#findComment-3899767
thanks man but this was after some full blooded runs at mallala so yeah i think it might be a dodgy stock gauge as the indicators went as well so yet to put the mechanical gauge on but if you can give some psi readings that would be great, so when i finaly get back to my car to check it out i know what im lookin for :D
https://www.sau.com.au/forums/topic/214069-oil-pressure/#findComment-3909484
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
