A quick Q about tyre profiles.
With the AWD system, what happens if you run say 35 profile tyres on the front and 45 on the rear?
Or even if you have 35, 40, or 45 all round, but have an underinflated tyre?
How would that affect the AWD system?
Someone asked me last night, and I really didn't have a close enough/accurate answer.
:blink:
https://www.sau.com.au/forums/topic/214253-tyres/
  • Replies 44
:blink:
This has been covered before in detail somewhere; basically attesa does not like this, unless you can very closely match the rolling radius. Some people have been getting vibration through the s/wheel, 4wd lights coming on etc. from using mismatched rolling radius's. I believe it will handle a millimetre or two (ie. treadwear) but 16's on the front and 17's on the back for instance no good (ymmv)
Just also thinking. If you're running 17" or 18" or 19" rims and you get a flat and fit the 16" spare, how does that affect things too?
Again shouldn't drive very far like this, attesa (and your diff's I suppose) will not like this; only a 'limp home' solution.
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783595
Okay so thats obvious, mismatched rim sizes is BAD :)
What about 17" rims with 35 profile front and 40 profile rear?
Or even same profile all round, but spanking new 40 profile on the front and 50% worn 40 profile on the back?
:blink:
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783599
I've only had issues when there was a 50% or more difference in wear between the front and rear, and it showed itself as a steering shudder on light throttle corners, and even then, only intermittently. Personally, I wouldn't mess with different profiles, but different wear of the same profile shouldn't be too bad...
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783613
Hmm,
Out of curiousity I just checked my tyres. I purchased two sets of rubber on Tuesday and didn't think about mismatching profiles. Never gave it a second thought. Seems I'm running 40 on the front and 45 on the rear on 18" rims. I'm not experiencing any shudder or side effects, but I guess I should grab another set of 45s today for the front.
I only fitted the rims last night, and drove a whole of 8.5kms to work in 50-60kph zones, so I should be safe for today.
I'm gunna buy my friend a beer for bringing up the discussion. :blink:
Still on another note: it seems pretty silly designing an AWD system where unevenly worn tyres will result in more wear/stress on the AWD system. :) There must be some 'slip' there somewhere?
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783698
Here's what I found. They don't have to be exactly the same tyres. As long as the rolling dimension is the same or within something like a 2% tolerance (don't quote me on the exact percentage) it's fine. This is to allow for uneven wear and tear. i have different profile tyres front and back but the rolling dim is nearly the same (R - 235/45/17, F - 215/50/17)
there are a few websites to calculate rolling dimension (tyre circumference) that are quite good, here's one i googled. some other ones give you the actual % too.
http://www.club80-90syncro.co.uk/Syncro_we...0calculator.htm
EDIT: Here's a better one
http://www.nitinchordia.com/upsizing.htm
Edited by webng
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783886
I'd rather not.
WHY?
yuo have a Stagea, yoru not going to be breaking traction any time soon taht coudl be dangerous, less parasitic drag on your drivetrain.....
i mean, unless you drive in snow on a regular basis, is there a reason not to?
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783897
Thanks for that :blink:
I've done the calculations and the F circum is 1968mm compared to the R circum at 2040mm. Thats a 3.6% difference in circumference. At 100kph thats a difference between the two of 0.2kph.
I'll still play it safe and get another 2 235/45 tyres
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783910
WHY?
Because its my car not yours, and you are only speculating on how I drive now. So ... I'd rather not. :blink:
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3783923
When I first bought the car it had more then 2% difference on the circumference between front and rear which lead to a funny "farting/groaning" sound when I turned the engine off, and a strange shuddering at about 70kph. The Attessa reservoir dropped pretty quickly too but once i topped that up and got new tyres all was good.
re: rwd vs awd... I personally prefer awd, otherwise i would have bought the RS version wouldn't i. Much prefer the security of the awd, especially when wet.
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3784002
WHY?
Parasitic drag? In order for my Stagea to proceeed down the road the front wheels have to turn, whether that's by 4wd or via the rear wheels and the road. So all you are talking about is the small effort required to turn the drive shafts and the front diff, neither of which are excessively large (weight and drag). Especially in comparison to wheels, tyres, brake rotors etc. Lowering a Stagea too much soaks up more power than that. :down:
Cheers
Gary
https://www.sau.com.au/forums/topic/214253-tyres/#findComment-3784334
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
