Hi guys, im getting a pair of HKS GT-ss for my car, the thing is that it comes with garett 2860-5 actuators...
i read that the GT-ss and 2860-7 are the same turbos
my question is:
would 2860-5 actuators be compatible?? as the GT-ss are smaller turbos compared to the 2860-5
thanks guys
thanks for clearing it up guys
Garrett ones would be, HKS might be a tad higher as a base pressure. Not sure on that one
im not sure what you mean with this one,
are u saying HKS actuator has stronger spring hence = higher base pressure?
anyone knows how many psi HKS and Garett actuator good for, or are they adjustable?? never seen one before excuse the noobness
HKS actuator is suppose to be 50% stronger over standard therefore allowing you to wind up the boost and holding onto that boost when needed. IMO if your not going for crazy boost e.g over 1.4 bar i would not bother. spend money else where.
We just did this with some 2860r-7's, was told the Garret 2860r-5 actuators open at 16psi and I believe the HKS actuators open around 15psi (my GT-SS's arrived this week muhaha)
Both actuators have the threaded arm, so you can adjust the reach - so yep they are adjustable.
Edit: They are good for whatever as long as it is over the base pressure (so 16psi+ or 15psi+). Just depends how much air you bleed of the line that connects to the actuator - leave this disconnected and they might just never open. The turbo however, will break...
Edited by paulR32gtr
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
