Well just about 10mins ago some prick tried to break into my car at the front off my flat i just got back from a mates house and i just closed the door and was talking to my flat mate
then out off no where we here these 3 massive thuds then my alarm is going spastic ran out side with the trusty golf club and the f**k wit has vanished one off my other neighbours
gave chase and seen him runnin up the road and gave chase i soon followed with my mate we looked every where but no onegot back had a look at the damage and there's a few
rubber marks they tried to smash my drivers window with a rubber mallet.
I sugest every one be extra cautious who is in your area if you havent seen that car before approac h them and ask them in a firm way what the f**k are you doing here thats if you
dont know the car sorry for ranting on like this but im so pissed off right now.
cheers
Allan.M :D
Edited by R334door(s2)
https://www.sau.com.au/forums/topic/214385-attempted-break-in/
  • Replies 56
there's a few rubber marks they tried to smash my drivers window with a rubber mallet.
a real rocket scientist. Lets use something soft to break glass! :D
Good to hear it was a failed attempt. :D
a real rocket scientist. Lets use something soft to break glass! :down:
yeah telling me lol like your humor towards the hammer thats exactly what me and my flat mate are thinking right now. :D
Be funny if it bounced enough to smack the f**k in the nose :D
tis only a car man - not end of ur life.
But do what I do - if my car is parked on the street, i unbolt all of the wheel nuts on one of the front wheels - farked if i care whether or not they are stupid enough to steal my car - cos if they do, they will crash, and probably injure themselves.....
Haha never thought of that. Thats all well and good til an innocent person gets taken out by the crash or the wheel :D But yes it would be good if the thieves crashed and burned then died im sick of these scum.
lil old adelaide is turning into more of a shit hole than it already was :) aami fire and theft insurance here we come ... for piece of mind!!! even tho its behind two cars the amount of times this has happened recently!!!
glad to hear they did not take off with your pride and joy and glad not too much damage was done!! could ahve been much worse!! thank your lucky stars!!
:blink:
Sorry to hear Alan but as eMsta has all ready pointed out its only a car it can be replaced, not saying i wouldnt be devo if mine got stolen becuse mine is rarer to replace 4door gts4 with a proper engine conversion
i like the wheel nuts idea
good luck getting AAMI to isure you man 99% of aussie insurer's wont touch imports
:blink:
it;s getting to the point that i rarely drive my skyline nowdays for fear of parking it in a public place .
mine lives in the build on to the house brick carport behind locked roller doors . i never leave it in the drive wayor leave the roller doors up .bloody sad that it comes down to this just for a car . its clublocked has a great alarm system and a german shepard that would take a intruders nut sack off .
dont think it's been driven in a fortnight now really should sell it for the amount it gets used but the mrs loves the damm thing and wont part with it lol
sorry to hear what happened to your car but be glad it was just a failed attempt....i have recently got installed a few things like shock sensor.....and a really high frequency module that will blow ear drums out in 3 seconds or so....good luck to the f**ker who gets in my car when the alarm is triggered off....
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
