hey guys im getting a weird ticking noise that's proportional to the engine revs from the turbo side of the engine bay at low revs (from 1.5k to about 3k... not sure if it goes away at 3k or if its just too noisy, ie. pod suction/turbo spooling for me to hear it) and im getting worried i really dunno wtf is going on, im going to ice performance tomorrow to get it checked but was wondering if its a known thing or something so i KNOW to check something before i drive for 50mins over there, hopefully someone knows what im talking about
my car + mods are:
r33 gtst (95)
full zorst, pod & FMIC
profec b spec 2 EBC
powerfc w/hand controller
cars running at about 10.5-11 psi (0.7-0.75bar)
im scared something is really wrong last thing i want is a dead engine/turbo... oh and the car is still making perfect boost (is pinging a little bit but i think timing just needs a bit of retardation to fix that up)
https://www.sau.com.au/forums/topic/21454-turbo-ticking-noise/
Guest RedLineGTR
depends what the guys at ICE say thier is also a joint near chadstone called ATP they specialize in just turbos maybe they can give you some other feedback if ICE cant help ya which i doubt. I gotta checkout my car as well gonna head down to ICE probably wed at the latest finish work early.
i just let it wamr up to normal temp and then turned it off, removed dipstick, wiped it clean replaced it and waited 10seconds then took it out and it was sitting just underneath the L point on the dipstick, im assuming thats the way to check the oil and if that's the case then im totally outta oil, just put 500ML of new oil i had spare in running that through,, then will turn off and se if it goes up a bit, if thats the case that there wasnt oil then that explains the ticking... can i have done much damage ? and how the **** would have the car eaten up that oil ? what are the causes of a car eating oil ? coz it definnitely did not drip outt somewhere coz there was no oil marks whereever i parked!
:D
you only check your transmission oil straight after a good run, when it is hot.
Engine all should be checked when stone cold.
Sorry can't really help ya with ticking noise :D
But can the ticking be the boost selanoid (sp?) switching open/shut to controll thr boost?
Are you sure it is your turbo and not just your injectors or lifters? As after a hard dyno tune, a lifter may get a little noisy. Mine did, and went away after a long cruise.
Check your intercooler pipes for excessive oil residue. Really hope you don't find any, as it will indicate a worn eng./turbo (especially at a lowish boost level). May need to get an oil/air separator if that's the case.
its deifnitely not the boost controller as i turned it off :D been running stock boost for safety since i heard it
my oil sems very low.. will check tomorrow morning
god i hope there's nothing majorly wrong :D
will check intercooler piping however if its just low oil ill fill it up tomorrow and cruise to ice and let the pro's handle it
and redline.. i put in 4.5Ltrs approx
Well with nearly zero oil in there i think is probably the noise..
He can probably literally here the valves opening and closing or cams turning around because there is not enough lubrication in there.. not good whatever it is!
Hopefully the engine is all a-okay, but if its burned a whole 4L or so of oil in only a couple of thousand km's something not too good is going on.
You definately do hear ticking like that with low oil.
Did someone steal your expensive oil after watching you change it and get underneath with a spaner and collect your oil? - haha
Do that check oil level in the morning when cold.
Check your muffler - is it wet with oil slick?
you'd better fill your oil up again before driving it further!
check your oil pressure too - post that.
If its hot the oil would drain to sump sufficiently fast to get a reading accurate enough after half an hour. However if the oil filter is blocked you might have to take the reading while cold.
Blow by is a cause of oil consumption but usually its worse at higher boost. Blow by gets worse as the piston rings get worn.
hmm ok well i spoke to ice and told him the level of ym oil he saiod thats ok there's enough oil for it not do any worryful damage but its still a problem that needs adressing, ive got about half a gauge reading on oil nowb y topping up with leftover oil i had form last change (clean new stuff) and what ill do is fill it full before i hike to ice, gunna try it tonight to see if the clicking is gone, but nevertheless i wanna kno where my $60 per bottle mobil 1 has gone lol
maybe a catch can could help with this problem
so gortdon its chewed only a couple litres ice said if its at the level i quoted them
Sounds like you done a turbo seal dude, fairly common i'm afraid, often goes un noticed tho. I was going to say if you have a bigger turbo on it that'd be why cos of the design of some bigger turbos they sound like they are ticking but is acutally the exhaust sound resonating through the bigger blades, but only on some turbos. But def check you seal, could also be the reason why you are losing oil if it has damaged the bearing case and thrust bearing you could be using oil, check the inside of your cooler piping to see if its oily cos then you'll know you got oil in your turbo.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
