alright i thought id add my 2c. i love BOTH, the R32 and the R33. I wish i could own both. I always admire them when i see them on the road. Hell i even get waved at in my 33 by drivers(32,33).
Iv driven both. The R32 seems more punch, due to the lack of torque as compared to the 33. The 33 has more weight however has more torque. Stock for stock tho, the 33 will win.
The 32 i feel gives you more driver feedback. Neither of them are slow. The 32 likes to rev out. the 33 doesnt NEED to rev out as it has more immediate torque. Down low, the R33 will take the cake anytime, anywhere, however the 32 closes the gap at the top of the rev range as it peaks then.
I love the shape of the 32. damm sexy!
  • Replies 165
Posted Images
It doesn't close the gap at the top end... I overlayed a mate of mine's 205rwkw R32 GTSt dyno plot with my 280rwkw dyno plot from the same dyno. The R32 was running equivalent mods to mine (bigger turbo, ECU, injectors etc) but with more boost. His lag was about the same, and if anywhere the gap "closed" in the midrange which is probably mostly to do with the larger amount of boost - my dyno plot actually pulled noticeable distance away from his one above 6000rpm. Despite the hype, in my experience when you go a bigger turbo etc on an RB25 they rev harder than RB20s too, and still don't need to.
But RB25s are for lazy drivers who dont want to work hard for their performance :D Dont get me started on RB30s!
R33 is simply the better car on paper. Problem is cars of this age are all so different with regards to mods and condition. Your friends RB20 may not be as well bolted together as your RB25...soooo many variables. Here is an example of my RB20 vs two RB25s. So it all depends on the particular cars you want to compare as to what your opinion will be
But RB25s are for lazy drivers who dont want to work hard for their performance :banana: Dont get me started on RB30s!
Haha I'm not sure if you are joking or not, I knew someone who had that honest opinion. If you went from your RB20 to an RB25, do you think you'd suddenly not try and milk everything it has to give? You've done an awesome job of making RB20s look better relative to its RB25/26 cousins than it should do - I credit you and your car setup more than the engine, makes me wonder how you'd go with a decent RB25 or 30 :)
The dyno plot you have used there doesn't really show anything, all I get from it is you have a different tyre speed vs revs to the other two cars and are probably running more boost. Australia, for heavens sake - get some hub dynos!!
If your talking lazy then EVERYONE who drives a Skyline is lazy taking the turbo option... what a bunch of cheaters! Get a real car get a Honda - takes lots of money and work to get power out of those 4 bangers :banana:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
