  • Replies 56
i own a series 8 rx7
the car sure looks good, drives good.. when it drives
wat most ppl dont figure out b4 they buy one:
the reliability mods which MUST go on the car straight up
mazda just didnt build a mazda to last and used shit plastic crap in it
plastic AST (breather tank) will need to be switched to an aluminium one (if it leaks.. can kiss ur motor goodbye)
radiator is totally inadequate in stock form
exhaust is extremely restricitive, compliance will switch ur cat to one which is even worse than stock cat
solenoids tend to fail easily(break or crack in heat).. the twin turbo system is extremely complicated
ud need to do a compression test on ur motor b4 u buy it, anything less than above average/excellent.. ur motor wouldnt last too long .budget $5000 just for a rebuild minimum and about $1500 for upgraded apex seals.
to run any mods.. ud need an aftermarket ecu, PFC's are used quite alot.. dont use anything else.. they are junk..cept maybe motec. microteck, haltech, wolf watever are all junk
replacing IC is a fair job.. front mounts dont really work well on FD's.. they just look good. the best bet is a upgraded SMIC or a vmount..vmount will require u to get a vented bonnet
maintaning a fd is ALOT of $$$
my clutch line popped all of a sudden one time going across the harbor bridge..
my motor gave way after 1 month of ownership
security - fd's are getting stolen alot now.. make sure you have the best of alarms and full comp INSURANCE.. i learnt the hard way
ive owned my fd for 1 year exactly now.. its been off the road for 7months
if ur worried about fuel.. dont buy a fd
a stock fd would typically get u around 400km/450 max if u dont step on it per tank of 76L 98 octane.. if u are running aftermarket seals. ud most probably neeed to run pre-mix which is $35 for 1L...
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3803102
They are awesome. As soon as my car sells, i'll be buying a series 8 Type RS
As has been mentionened before, definatly look at the Type RS. More power, 17" wheels, Bilstein suspension, larger brakes, foglamps, 4.3 diff.
Get onto AusRotary and FD Owners forums and find out as much as you can about them. Also, check out this website Click here. When I started looking into them, I found this site to be a great source of info.
Good luck!
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3803304
series 8 Type RS?
how much are one of these.
the is saying he wants an RX7 until he can afford an R34 GTR. which seems to be under $50K these days via import.
he post by KIN seems to be what I've heard from my mates with rotaries.
One has a series 6.
the radiator issue was his cause for rebuild.
thw twin turbo's and their well known problem of cracking the rear housings caused him to get a bigger single.
the bigger turbo need for FMIC caused him to spend ALOT of money on cooling upgrades.
They are sweet looking cars.
no doubt about it.
and they go like shit off a shovel.
well balanced etc etc.
but man.. if you are going to buy one, spend extra and buy one already rebuilt with all the problems that KIN has posted, already fixed with receipts to prove it.
It's very much like buying an 89 GTR for $15K... you gotta have another $15K to sort it out once it pops.
and they all pop. unless you granny it. but who buys skylines or rx7's to granny?
Edited by GTST
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3803911
You're better off with a good low mileage original engine or one that has had a new OEM block. Other than that, look for one that has been rebuilt by someone respected - ask around (see link above).
In 100% stock form, they are great. With a series 8, the only thing you really should do is replace the air sep tank (AST) with an alloy version (you can buy one from JustJap for under $100, or spend a few extra on something 'JDM' brand name).
But who can leave a car like this stock?
Once you start adding things, then you have to consider the car as a whole - not piecemeal modding. Add an exhaust, add a PFC (for series 8 280ps version - not such an issue with lower power versions). Add an aftermarket IC, add an upgraded radiator.
They're not that difficult. Unfortunately, the average citizen of the world is a moron, so they are not for everyone. If you are willing to do a little research and do things patiently and properly (i.e. your first mod should not be an ebc), you will be hugely rewarded. Otherwise... buy a toyota.
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3804377
"budget $5000 just for a rebuild minimum and about $1500 for upgraded apex seals."
Thats not really too true, unless your talking about a rebuild with new turbo manifold/turbo/wastgate etc. My brother had his rebuilt and with aviation spec seals and it was less than $4,000 drive in drive out. My rebuild at SCR was 6-7k with heaps of upgrades.
"if u are running aftermarket seals. ud most probably neeed to run pre-mix which is $35 for 1L..."
Not true either...I had SCR steel race seals in my FC and it ran perfect on 98ron fuel, also my brothers FC with Aviation seals was the same. No need for crazy high octane fuels unless your running huge boost(18psi+), and you just dont need to do that to make big horsepower in a rotary anyway because they can handle bigger turbo's running lower boost whilst remaining responsive. My FC had a GT35R with 1.06 rear housing and it had less lag and was more responsive than the stock turbo....
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3804774
Is it possible to convert the sequential TT setup on the RX7 to parallel, as can be done to a Supra? That would be interesting :D
Common (most often suggested by workshops who can't troubleshoot the sequential - i.e. nearly all of them).
No real performance benefits on the street (a smidgen more kph over 400m), and a big negative - loss of power at the bottom end. And that's only when it's done properly, more often than not it's a 'poor man's' hatchet job - which has even worse response.
Sequential twins are far and away the best choice for a daily driver/street car.
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3805702
Thanks for the post. I thought parallel (never having owned one) would be better??? I'm a TT noob, could you explain why the parallel setup on an RX7 would reduce response? I know with sequential the smaller turbo gives quick boost, followed by the larger turbo for top end- but it they run together what real-world effect does it have?
Edited by R338OY
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3805771
It's not the same as the supra set-up.
When you remove the sequential system you don't get the low-down spool that the primary provides. Instead, you get boost later (somewhere around 3500 or 4000) - i.e. lag. It's like having a shit single (so you might as well get a good single). You don't really want to be taking low-end response away from a car that doesn't have much capacity (and therefore torque) on the menu.
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3806144
dude dont take it word for word.. someone could rebuild for 3k.. some could do it for 10k.. depends wat else u do, porting, studkits, which seals, how may housings need replace, how many rotors need replace. i could have my block rebuilt for 3k if it was just replacing seals.. and my housings etc were fine. its just like comparing a 2500 paintjob with 10k job.. exactly the same shit.. just different work and different quality
seals will depend on which type again.. i said MOST PROBABLY.. i use PTS seals and its a must to run premix... and premix has nothing to do with octane levels.. its just lubrication for ur seals.
lol!! read it again.. premix - 2 stroke oil... not octane booster man..
so read more carefully b4 u try take some1 apart thanks
Edited by Kin
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3806416
i ran pts seals and i didnt run a premix.. wtf for. every rotor engine has oil squiters for this reason.
Its just a myth.. premix belongs on 2 stroke motors and despite what most people believe rotarys are 4 stroke motors.
as for rebuilds.. i got the engine with the lot.stud kits, pts seals, bridgeported (exhaust included) had rotors balanced and 1 housing replace and some race bearings. 5k later... :P
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3808575
lol.. mate... its up to u wat u do. ur seals are just going to wear out without premixing
maybe speak to the makers of PTS seals.. ask them why you need to premix
https://www.sau.com.au/forums/topic/215185-rx-7/page/2/#findComment-3808648
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
