  • Replies 41
Posted Images
Not identical...
... but close enough for me.
nah mate, that photo of the R34 is in very bright light. Bayside blue is quite deep and quite dark. That V35 blue is a deep metallic baby blue.
But hey, if you like it - that is all that matters :banana:
You can't go past a black V35 imho. If I see another bat-shit-boring silver one on JSpec I am going to puke.
Yeah bayside is a bit darker, but it's highlight colour is the base colour of this one. And it's that colour i really like. It's kinda like the trust / nismo / cusco blue used on parts etc. Very bright and candy style.
Silver looks classy but there are just so so so many of them.
Black, so hard to clean, look good, but i will never do it!
Red looks.... hmmm not a fan on the V35
Blue, something different, rare and stands out.
Have you done much looking........
2004 B6 A4 Quattro Wagon, 6sp Man 94,000km 35k Killa 4wd Wagon with a features list linger than my arm
http://www.carsales.com.au/used-cars/priva...0&trecs=131
2003 A4 Quattro Sedan tiptronic 75,000km 31k
2002 B6 A4 Quattro tiptronic 73,000km 34k
http://www.carsales.com.au/used-cars/priva...4&Make=AUDI
Heres the search i did over Australia,
http://www.carsales.com.au/used-cars/AUDI/...&state_id=0
My bro in law used to have the model before in the A4 Quattro,he had koni coilovers and 18s and the thing handled like it was on rails, None of this Japanese stuff feels or handles like a Euro car, and by the looks of it you can afford some of the better ones, and they go forever provided they are serviced, My old BMW was a dream to drive, if it had as much power as my 33 had then it would have handled way better with just king springs!!
At the end of the day it up to you obviously, but when spending that much on a car just make sure you have gone thru all the options!!
Edited by Deluxe
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
