Guest Robo's
Ive got a Apex pod filter, and agree im defeating the purpose of having hot air go into the turbo and then get pushed out at a much hotter temperature, then letting the stock cooler trying to cool it, before going into the plenum.
So why not trying to reduce the air coming into the turbo through a cold air system. I dont want to cut any holes, so i thought get a stock box with the over the radiator duct and try and hack the box to make the pod fit. Then try and have another cold air duct enter the box from underneath or something, probably only room for a small tube.
Anyone done something like this?
https://www.sau.com.au/forums/topic/21548-pod-in-stock-airbox/
Originally posted by Champinco
i have a qn..im new to this whole POD thing. all i know is that i have an HKS POD with a HKS big intercooler. would i or do i have to partition off the POD???  (put a box surounding around it?)
Cheers
Yes. Otherwise you should go back to the stock airbox.
A pod filter with no partition will cost you performance every time.
See this thread: http://www.skylinesaustralia.com/forums/sh...&threadid=13003
Thought about it but have you actually ever pulled the airbox out? It is far too small to fit a pod filter inside and if you could find a pod filter that small it would actually reduce performance due to friction, and generally a lower filter surface area than the stock panel.
I then thought of building a fiberglass box that would take the stock airbox lid and fit a pod filter inside.
That seems to be a better idea maybe.
Guest Robo's
I had a feeling it would be too small, (i havent seen one) hence why building a small box, so if a pod is illegal, then a partition is illegal too, so we have to put a lid on it?
It's not illegal because it lacks a lid, it's illegal due to the EPA restrictions. That is it's too noisy (induction noise and the like) and the changes in emissions which may occur due to the changed intake.
Putting a lid on it is a way to lower the probability the cops are gonna defect you for it during an under bonnet inspection, but if they heard a blow off valve type noise from your car they probably wont know/care where it came from.
Cops seem to think that "blow off valves" are illegal tools of the devil. I would like to know if many of them actually know theyre just another part of a standard proper turbo car setup.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
