yeah you could maybe import one for 20k
but why not buy mine for 20k or there abouts
and it already has reg, compliance, major service, timing belt, and new clutch
and you can actually drive and look at the car
^^Timing I guess.
Ppl gota be in the market for one before you get a buyer... It will still sell... takes time.
Put it on Car Sales / Car Point / Drive.com.au / SAU For Sale Thread / Trading post ect
Petrol prices are going up / new P Plater laws are coming in, not easy owning a GTR with all the cost involved. (Just speculations)
hi,
original [absolutely no mods], quality [genuine low km] GTR r32 are rare now and should fetch a good price. when I was trying to buy one, January, there were several for sale in the mid 30k range. there was a V spec 32 for 37k, so look/wait [if you are not desperate] for the buyer who wants a good 32 and is willing to pay, believe me, there are plenty of people out there who would like to own one. there are GTR 32 in crap condition selling for 18k.
good luck anyway.
regards
I have been through the import exercise and you can't import a genuine, low km , original GTR r32 in good condition for 20k. they are bringing that, and more, at auction in Japan. so add on all the import costs, compliance, etc and you will be pushing 27k +.
thankyou
it seems like everyone out there thinks that actual decent gtrs are going for under 20
i reckon anythin under 20 is going to be a very poor example
you get what you pay for at the end of the day
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
    • As far as I can tell I have everything properly set in the Haltech software for engine size, injector data, all sensors seem to be reporting proper numbers.  If I change any injector details it doesnt run right.    Changing the base map is having the biggest change in response, im not sure how people are saying it doesnt really matter.  I'm guessing under normal conditions the ECU is able to self adjust and keep everything smooth.   Right now my best performance is happening by lowering the base map just enough to where the ECU us doing short term cut of about 45% to reach the target Lambda of 14.7.  That way when I start putting load on it still has high enough fuel map to not be so lean.  After 2500 rpm I raised the base map to what would be really rich at no load, but still helps with the lean spots on load.  I figure I don't have much reason to be above 2500rpm with no load.  When watching other videos it seems their target is reached much faster than mine.  Mine takes forever to adjust and reach the target. My next few days will be spent making sure timing is good, it was running fine before doing the ECU and DBW swap, but want to verify.  I'll also probably swap in the new injectors I bought as well as a walbro 255 pump.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
