phwoar. i reckon ive got about 250, so we might give it a good shake! smash all the hsvs there running 14s.
it sounds like you haven't run your car at WSID before correct?
if so, don't be surprised to get a few 13-14 second time slips before your 250rwkw gets you something like a flat 13 or high 12.
youre right. im realistically expecting low 13s, theres a lot of time to lose in the launch i guess.
I had 5 runs on my first time there in a 200sx.
first run was a 14.8
last run was a 13.8
every run I did, I thought, I'll change this next time etc and it kept improving.
lots of fun. espesially the 14.8 run, which was, wheel spin, wheel spin, wheel spin, wheel spin, rev limiter in first, second, wheel spin, wheel spin, wheel spin all the while swinging the rear left to right and back... rev limiter in 2nd, 3rd, bog... then eventually cross the line just hitting the limiter in 3rd.. lol.
haha must have had no traction at all! my car has tons, except when its wet lol. when i launch off the lights i might wheelspin a bit through 1st, little chirp into 2nd then off she goes!
yeh.. it was more to do with nerves and 45 psi in the rear wheels (which were 255/35/17).
I eventually got a 1.9 60" with good controlled launch and 19psi in the rears.
are you using your street tyres?
what are they?
255/40/17 bridgestone potenza streets, id say they are pretty high-end since they were over $400 each. i run around with 36psi, and it says on them "traction - AA" haha.
too bad they only last 15000km.
I think its do-able ... 240kw netted me a 12.4 that's with poor clutch and tires... Im confident i could post a very low 12 now.
Sti is fair bit lighter, so with the right driver who isn't nervous on take off should be in lower 12 second bracket.
Edited by Tomek
it can be done no worries
i have a mate with a wrx sti 2000 model
239kw at the wheels
12.3 down the quarter ill call him to get the time slip and try and find a scanner at work
wrx's are so expensive to modify as well the power really has to be dragged out of them not like a gtr where u just upgrade turbos
cheers
julz
239kw at the wheels
cheers
julz
how are they more expensive to modify? power fc + td05 (big wheel turbo?) + fuel pump + ebc gets em to 200 + awkw. they dont even need to change injectors till 250awkw..
same mods as gtr's, only gtr turbos cost alot more and gtr's need to upgrade injectors to get descent power/weight figures compared to the wrx
well he modded his wrx and i modded my gtr and he spent way more to get basically the same power at the wheels
does that make sense
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
